Help. Sony kd-65x85dj vertical lines
  • visionbluedemon
    • Nov 2017
    • Philippines
    First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
    Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
    tried blocking LC lines too, but same results
    is it lcd panel issue or tcon board issue?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4326
    • Italy - Milan
    post picture of bad video.. otherwise describe it in full particulars..
    • visionbluedemon
      • Nov 2017
      • Philippines
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        Appears the Vcom voltage has some flaws, it could be too low, so when the turn of source voltage must be negative respect to vcom, with the vcom low the resulting value of pixels source is much positive, so a dark pixel is displayed brighter.. the most possible cause is a degradating connection in ribbon connection.. no solution by me for now.. i stopped troubling with these damn things.. bye
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
