Pana plasma TC-P50C2 one blink error
  • hienton2
    • Sep 2009
    • 183
    Hello Good morning.
    I have pana TC-P50C2 plasma. It has one blink error. At first when I brought
    home It is on after trying to turn on 20 times.Then I take off back cover to check power supply. It is never on , just one blink.
    I do not have training troubleshoot manual.
    please help.
  • tw2005
    • Oct 2011
    • 6458
    Re: Pana plasma TC-P50C2 one blink error
    generally speaking 1 blink is a faulty A board
    • hienton2
      • Sep 2009
      • 183
      TW2005.
      I can not find this A board on any distributor.
      • cliff_hootarski
        • Jul 2006
        • 411
        You can get it repaired here:
        http://www.moduslinkptstvboards.com/TXN/A1LNUUS/
        • Ltank
          • Jun 2013
          • 776
          Encompass has it. Return your original as core reduces the price by 125 bucks
          http://www.encompassparts.com/item/8...LNUUS/Pc_Board
          Partstore has it with no core charge but is way too expensive
          https://www.partstore.com/Part/Matsu...LNUUS/New.aspx
          • hienton2
            • Sep 2009
            • 183
            Only Moduslink is available for repair.
            Thanks guys
            • tw2005
              • Oct 2011
              • 6458
              Thanks guys
              If you get it repaired, see if you can find out what they replace or the fault was.
              Or take a clear picture of the board top and bottom and then compare it to what comes back, may be able to pick it.
              I've had a 1 blink and tracked it down to a faulty eeprom for the panel addr data.
              post 14
              https://www.badcaps.net/forum/showthread.php?t=30054
              There is another TC-P50c2 thread about 1 blink, With my theory one of the guys tried eeprom swapping to fault find it, with little success but then tried another eeprom from another board (model unknown, his problem may have been the wrong data loaded on the eeprom)and reckoned the SOS1 cleared but he had poor picture or maldischarge.
              https://www.badcaps.net/forum/showth...light=tc-p50c2
              post 31
              Originally posted by freakaftr8
              I tried a replacement eeprom from another a board. Cant remember exactly what model it was but I got a picture but it was all mal discharge looking. I gave u p and replaced the board
              If indeed it is an eeprom issue, they appear to be available and cheap.
              One is about IC9304 $7, and the other about $5.
              It's a stab in the dark for sure.
              • hienton2
                • Sep 2009
                • 183
                TW2005.
                I have 3 question for you
                If I want to change IC9304 and 9001 Where I can buy them ?
                As $7. a piece as you said
                Is there any different between
                TNPH0831 2A and TNPH0831 3A
                both have part#TXN/A1LNUUS
                Do you has this manual ?
                Try this - it's not the exact training guide for your set, but may give you a starting point on the 1 blink code:
                • tw2005
                  • Oct 2011
                  • 6458
                  TW2005.
                  #1 When someone puts a link to another thread for the same model and fault, do you read it from start to finish?
                  The answer to #1 is in there, in fact 3 answers I think
                  #2 The only numbers you need to worry about for finding the right board are either the board number TNPA0831 combined with the revision AV,or TXN/A1LNUUS
                  So, TXN/A1LNUUS & TNPA0831AV are the same. Should be able to confirm what rev the board is by a SUFFIX legend imprinted on the board.
                  #3 Strange, tried the link and got GODADDY?
                  NOTICE: This domain name expired on 4/08/2014 and is pending renewal or deletion.
                  Might just have to give me the guide name, I'll most likely have it.
                  I don't know exactly how you fault find a 1 blink, but I can confirm a bad eeprom whether it was faulty or the data onit corrupted caused a SOS1 on a board I was coverting from another 1 blink faulted A board.
                  Also there are other related models which if stuck you could use their A board but it will have different features, but it appears what little is out there and the prices it's cheaper at $110 to get yours repaired by Moduslink
                  • hienton2
                    • Sep 2009
                    • 183
                    Thank you very much TW2005.
                    You are very helpful
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
                    • rmacintosh
                      Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                      by rmacintosh
                      I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                      The symptoms of the tv ar as follows:
                      • Plug AC in to back of TV
                      • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                      • The 3 blink code is given by the power LED
                      • If the TV is unplugged and then
                      03-14-2020, 12:24 AM
                    • EazyBone
                      Un50cu7000 2 blink oddity *partially solved
                      by EazyBone
                      I write this to maybe help another with this TV.
                      So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                      The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                      03-18-2024, 10:24 PM
                    • orbit417
                      Panasonic Plasma tc-p55vt50 6 blink error code
                      by orbit417
                      Hi All,
                      Thank you in advance for your advice.
                      I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
                      I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
                      I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
                      04-14-2021, 09:11 AM
                    • Vebririon
                      panasonic TX-P50V10E 6 blink led problem
                      by Vebririon
                      I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                      Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                      I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                      05-17-2025, 10:16 AM
