inova nt24 24 inch backlight problem
  • gasinmars
    • Apr 2013
    • 53
    • israel
    Re: inova nt24 24 inch backlight problem
    so how volt it chould be?
      The way these strips work is by current drive. The current drive should be in the region of 20mA to 60mA and depending on the number of LEDs, the forward voltage will vary from 20 to 100V. However I have not found many manufacturers who publish this info.
      • gasinmars
        • Apr 2013
        • 53
        • israel
        if it's 69 volt , is it good?
          I HAVE NO IDEA. Manufacturers DO NOT PUBLISH this information!
          Read my post above!
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            We dont know! It might help if you can get and information from the panel
            Is there a sticker on it Make manufacturer model etc
            • gasinmars
              • Apr 2013
              • 53
              • israel
              #26
              so how to check the fault if it is the panel or the board?
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #27
                Dismantle the panel and check the lamp strings
                • gasinmars
                  • Apr 2013
                  • 53
                  • israel
                  #28
                  i checked with another lamp and it's not working
                    Lamp, i.e. a CCFL tube? Or actual LED light bar? Remember each light bar is different!
                    • gasinmars
                      • Apr 2013
                      • 53
                      • israel
                      #30
                      • gasinmars
                        • Apr 2013
                        • 53
                        • israel
                        #31
                        is there any other way to check this ? look i also check the output of the two pins from the inverter driver board and it shows 69 volt ? is that normal ?
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #32
                          No.
                            Asking the same question will not get you any more information than we've already told you. You need to check the light bar.
                            • gasinmars
                              • Apr 2013
                              • 53
                              • israel
                              #34
                              look i figured out what is it , inside the screen i removed the black tape on it and recognized that the cpu is damn hot , so the problem is with the board of the screen that is connecting with the cables. is that right what iam saying ?
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #35
                                Maybe - post a picture of it?
                                • gasinmars
                                  • Apr 2013
                                  • 53
                                  • israel
                                  #36
                                  the cpu of the board that is assembled to the screen (not the vedio board or powersupply)
                                  is to hot.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #37
                                    How hot is too hot?? Picture of it might help
                                      That's probably the T-con board, and since you have a fault with the backlight, it is probably not the fault. The fault will be with the LEDs or potentially (though quite unlikely) with the LED driver board, if the output voltage is too low.
                                      • gasinmars
                                        • Apr 2013
                                        • 53
                                        • israel
                                        #39
                                        how many volts the inverter drive shoul give (output ) 12 volt?
                                          Do you even read the posts above, WE DON'T KNOW...
                                          • Dobrowol
                                            Asus GA402RK keyboard and kb backlight problem
                                            by Dobrowol
                                            Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                            04-28-2025, 04:30 PM
                                          • gabrielA7
                                            Macbook pro A1706 / Backlight flex cable compatibility
                                            by gabrielA7
                                            Hey guys!!
                                            I’ve got a question here!
                                            I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
                                            Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
                                            Here’s what the bot told me:
                                            I said to him: “I’m going to install the 821-01229-A.”
                                            ChatGPT replied:
                                            Understood — but before you solder or install the 821-01229-A,
                                            11-11-2025, 03:26 PM
                                          • fanaticgames
                                            Samsung UE32D4010 Backlight problem, led ok
                                            by fanaticgames
                                            hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                            02-22-2023, 09:46 AM
                                          • Honziq
                                            Backlight problem - Asus M3200WU, board Gapal LA-L291p
                                            by Honziq
                                            I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                                            I was repaired many backlights before but this design i will not understand.
                                            For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                                            Can someone explain me please what to do, what to check?
                                            Thanks....
                                            11-20-2024, 01:24 PM
                                          • grbo92
                                            Backlight problem Acer LA-031P
                                            by grbo92
                                            i have one acer Nitro 5 without backlight on my desk.
                                            Mainboard model: LA-L031P GH53Z REV 1B
                                            Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                                            11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                                            Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                                            Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                                            09-09-2024, 03:49 AM
