inova nt24 24 inch backlight problem
    Re: inova nt24 24 inch backlight problem
    so how volt it chould be?
      The way these strips work is by current drive. The current drive should be in the region of 20mA to 60mA and depending on the number of LEDs, the forward voltage will vary from 20 to 100V. However I have not found many manufacturers who publish this info.
        if it's 69 volt , is it good?
          I HAVE NO IDEA. Manufacturers DO NOT PUBLISH this information!
          Read my post above!
            We dont know! It might help if you can get and information from the panel
            Is there a sticker on it Make manufacturer model etc
              so how to check the fault if it is the panel or the board?
                Dismantle the panel and check the lamp strings
                  i checked with another lamp and it's not working
                    Lamp, i.e. a CCFL tube? Or actual LED light bar? Remember each light bar is different!
                        is there any other way to check this ? look i also check the output of the two pins from the inverter driver board and it shows 69 volt ? is that normal ?
                          No.
                            Asking the same question will not get you any more information than we've already told you. You need to check the light bar.
                              look i figured out what is it , inside the screen i removed the black tape on it and recognized that the cpu is damn hot , so the problem is with the board of the screen that is connecting with the cables. is that right what iam saying ?
                                Maybe - post a picture of it?
                                  the cpu of the board that is assembled to the screen (not the vedio board or powersupply)
                                  is to hot.
                                    How hot is too hot?? Picture of it might help
                                      That's probably the T-con board, and since you have a fault with the backlight, it is probably not the fault. The fault will be with the LEDs or potentially (though quite unlikely) with the LED driver board, if the output voltage is too low.
                                        how many volts the inverter drive shoul give (output ) 12 volt?
                                          Do you even read the posts above, WE DON'T KNOW...
