Philips 47PFL9603H fault or not?
  • PowerAmpFreak
    • 982
    • Sweden
    Hi all
    I have this Philips 47PFL9603H everything works except for speaker outputs.
    Even headphone output is OK.
    In audio usermenu there is an option "TV speakers on/off" but it's all grayed out. It cannot be selected.
    Tried factory reset in user menu, went into SAM mode checking option numbers, they all are exact like option codes on rear cover.
    Wonder if this could be a corrupt mainboard or any else weird feature??
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Philips 47PFL9603H fault or not?
    had a similar issue with one of these,but a smaller version,turned out to be a firmware update was needed downloadable from the phillips website,thats if you have a usb port and stick handy
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Not sure on this model but some similar ones I've had have a 24V rail on the power supply labeled AUD (Audio). I had one power supply that wasn't putting out power on these pins and a second TV that simply had a loose connector between the main and power supply. That TV was showing the same symptom you are describing.
      • PowerAmpFreak
        • 982
        • Sweden
        Thanks for advice. "Unfortunately" the PSU supplies the audio (24V).
        Will check around for loose connectors ...!
        Went into firmware update, but the set was already updated according to update application.
        Also replaced the class-D amp chip with no difference (just in case)
        • eurgenca
          Philips TV 43pus7505 setting display option code, help please.
          by eurgenca
          Hello.
          I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
          So I ordered a used CPU board, and now I have wired picture.
          I think the problem lies in display option code. According to SM, the command for setting
          display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
          But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
          or can I manually edit option code in SAM.​
          10-07-2024, 02:09 AM
        • alltvrepairs
          Philips 55pus6754/12 FZ3A Set Option value dilemma
          by alltvrepairs
          I need to change the main board for this set. I have a new identical board but for a smaller model 43PUS6704/12 FZ3A
          The picture is not good and remote seems not to work either.
          The Set Option on the rear of the TV says 042 as shown in pic.
          The Service manual lists this model but with another screen with a mentioned Option Code of 109. I assume that I need to use the one on the back of the TV.
          The problem I don't know how to tackle yet is the remote issue as not responding. Remote works on another Philips TV.
          03-16-2023, 06:06 AM
        • alltvrepairs
          Philips 50PUS8555/12 Power supply fault
          by alltvrepairs
          715ga018-p01-006-003s
          Am trying to find a pdf .
          i have no secondary output voltage. So far done the obvious checked supply on primary caps 320v, supply on power supply ic found 22v and cannot see any burnt components.
          tried with meter most components like resistors diodes etc.
          in secondary there are no shorts either.
          This was struck by a lightning and could see a burn under the air gap capacitor.
          Attaching the board.
          Any clues welcome.
          Tks...
          08-30-2025, 08:42 AM
          Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
          This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-06-2024, 08:00 AM
        • Biruslapio
          Philips 50 Inch 6654 4k display fault
          by Biruslapio
          Hi, this TV is from the PUG series, had no image, upon using tape to cover the pins on the right side(from the back), it displays only vertical bands that fade away slowly, classic problem with the horizontal part.
          There is no short I could find on the panel, when disconnecting any major voltage such as VGH, the T-Con stops pulling down all voltages and I can measure what they should be.
          I tried to use an external power supply in place of VGH, as soon as I turned on the tv displayed proper image and then instantly started to fade, T-Con shut down all voltages, it is sensing...
          04-10-2024, 11:13 PM
