LG 50PT350-UD Abnormal Picture
  • crdz66
    • Nov 2012
    • 242
    Hello Everyone.
    I have a LG Plasma Tv with a lot distorsion on the image.
    Recently I change for brand new main board and after couple minutes working fine, the problem is back.
    Check the pics.
    Any opinion can be greatful.
    Re: LG 50PT350-UD Abnormal Picture
    Can you post a picture of your control (CTRL) board. This is in the centre of the TV and generally connects to all of the other boards in the TV set. It connects to the main A/V board, which is the board with the video inputs on it.
    • crdz66
      • Nov 2012
      • 242
      ok. I will
        OK just right of text IC103, under the rectangular chip, there are two holes.
        Get a piece of wire, short the holes together, make sure it is firmly connected. (Do this with power unplugged.)
        Disconnect the connector on the right of the control board, it's held down with tape. You can unplug it either at the main board or on the control board, whichever is easiest.
        Plug the TV in, and if necessary take it out of standby.
        You should see these test patterns, or very similar:
        https://www.youtube.com/watch?v=9Lcq...k&noredirect=1
        Let it run for some time. Check if the patterns distort, or if they remain stable.
        When you go to turn the TV off, in auto test pattern mode first put the TV into standby using the remote/buttons before unplugging it.
        • crdz66
          • Nov 2012
          • 242
          question.
          How can I put into or out standby using the remote?
          I check couple thinks on control board.
          There are two regulators and show 3.29v and 1.19v
          The Led is blink some time not steady. (good or not?)
          The connector to y-sustain board show values too low
          like:
          connector actual value.
          23 (15v) 2.74v
          25 (15v) 1.12v
          27 (5v) 0.22v
            Just turn the TV on or off using the ordinary power button on the user remote.
            • crdz66
              • Nov 2012
              • 242
              what can I expect?
              if the patterns distort?
              if they remain stable?
              thanks
              Just on black/white show distorsion.
              vertical and horizontal patterns.
                If they distort = Ctrl board or possibly a sustain board (v. unlikely)
                If they do not = Main board (you may have gotten a bad one) or LVDS cable issue
                • crdz66
                  • Nov 2012
                  • 242
                  Picture from Y-Sustain Board
                  Last edited by crdz66; 08-13-2014, 04:22 PM. Reason: Looks like a mess on this board.
                    So you are saying the moving patterns have distortion on them? In which case, replace the control board.
                    • crdz66
                      • Nov 2012
                      • 242
                      Thanks Tom
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • CyberPhoenix
                        Issue with picture quality of Sony bravia TV
                        by CyberPhoenix
                        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                        01-22-2024, 02:08 AM
