QN75QN85BAFXZA no backlight
  • howardc64
    • Jun 2017
    • 590
    Originally posted by Diah
    if you found shorted Diode #2, then why you searched for driver boards and lotas went with to look forward new driver boards.. ? if you removed the shorted diode r´the circuit will work in kess one zone !
    Yes, as noted in post #1, this TV had prior repair attempt by Samsung. What they did is unclear but I guess they likely changed the PSU and failed again after working 1 hour. So have suspicion downstream hardware (LED driver board, mini LED array) has fault that is causing PSU to fail quickly.
    Anyway, so far LED driver board have no evidence of clear fault so I will probably just repair PSU shorted diode soon to start testing.
    • howardc64
      • Jun 2017
      • 590
      UPDATE : Got the backlight to turn on...
      Studied the circuit of the shorted barrier diode rectifier array. There are 2 arrays (2x 150V 20A diode in each array) with total of 4x 150V 20A diode working in parallel. Since only 1 diode failed, I guessed 3x parallel is reasonable design margin to test the TV. Cut the shorted diode leg and TV backlight turns on.
      Click image for larger version  Name:	IMG_4588.jpg Views:	3 Size:	1.92 MB ID:	3675303 Click image for larger version  Name:	IMG_4586.jpg Views:	3 Size:	2.88 MB ID:	3675276
      Now I notice likely the original problem. LED driver voltage is 69V while the board has printed ~64V with up arrow. I also notice its 69V constant regardless of content brightness. Ran black video and dimming zone test on youtube and dark area backlight does not dim/turn off. This maybe the original problem that caused the PSU to fail.
      It appears zoned dimming is not working and mini LED backlight maybe on full brightness. Changing brightness doesn't change any brightness. Tried local dimming with standard and high (settings are low, standard, high) doesn't have any local dimming with above youtube tests.
      Found firmware disabling local dimming is a massive problem on this TV ( link link ) If without dimming is full brightness, then LED driver would feedback to PSU to provide max current and voltage. Updated to the latest firmware (1661.6) no difference on backlight dimming. Probably need to find a way to downgrade firmware if thats possible.
        • 12116
        • U.S.
        Wonder if they just didn't use components stout enough to handle the loads, those samsung bean counters like to save pennies at the consumers expense.
        • Diah
          • Feb 2013
          • 6357
          you need now to replace the diode complete not just cut..
          • howardc64
            • Jun 2017
            • 590
            yes of course. Just did this to test until replacement part arrive.
            I don’t know this diode would cause 69v instead of ~64v spec printed on the PSU. Don’t fully understand the circuit. The 4 diode’s anode are on the PSU <-> driver board ground plane. Also I’ve seen wrong voltages printed on PSUs before although this board prints 1/10 volt resolution.
            Will go through service menu in detail. Other Samsung’s have settings for lower backlight level.
            • howardc64
              • Jun 2017
              • 590
              Looks like many Samsung mini LED backlight TV owners are struggling with local dimming not working. Some owners (gamers?) dislike local dimming so I wonder if Samsung may have turn it off as default in a way that no one can easily turn back on in recent firmware updates.
              Tried lowering PWM_INI_2D and PWM_MOVIE_INI (both 100 default with latest firmware) to 20, no difference with youtube dimming/black screen test videos. Did find someone posting their SubSetting menu (in service menu) and a couple of differences from mine
              • Mine has no PWM_MIN
              • My 2D_DimPosi1 is 2x bigger. Didn't dare to change this not knowing if this is related to different number of mini LEDs of different size TVs.
              Here is my Service Subsetting menu
              Here is another persons ( link )
              Anyway, nothing is causing LEDs to dim and PSU LED voltage rail is always 69v
              • lotas
                • Jan 2016
                • 4554
                • Russia
                #27
                LEDs do not work from voltage, but from current strength. Less current is supplied to the LED - it glows weaker, more current is given - the LED starts to glow brighter, heats up more, thus the crystal degrades faster...
                That's why, when they change a new LED backlight, they reduce the current in the backlight driver (increasing the resistor resistance) so that the LEDs last longer, and all TV companies set it from the factory to the maximum permissible current (so that the picture is as bright as possible) and thus, after two or three years, the backlight becomes unusable, just when the warranty ends.
                • howardc64
                  • Jun 2017
                  • 590
                  Yes, I always avoid max brightness on LED TVs. 6V LEDs (typical TCLs) seems more easy to fail.
                  On this TV, I wonder why have 69v instead of ~64v printed on the PSU. Maybe printed # is wrong. Maybe LED driver baord is requesting higher current which should show higher voltage if resistance path doesn't change?
                  But PSU LED + - isn't final individual mini LED current on this zoned mini LED TV design. So I wonder why driver board needs to request more current from the PSU? Anyway, still trying to understand the design.
                  LED driver board does have a feedback signal to the PSU. Will monitor this soon to try and understand the design. PSU LED + - isn't final individual mini LED current on this zoned mini LED TV design. So I wonder why driver board needs to request more current from the PSU?
                  BTW, eliminating the shorted diode solution (just temporary until replacement part arrive) actualy reduced the design capacity by 50%. LED + and - rail have 4x diode on each rail. The 4x diode has 2x with current flowing in one direction and 2x flowing in the opposite direction. So eliminating 1 diode reduces 1 direction from 2x 150V 20A diode to just 1. But I don't think this eliminated diode can change the voltage from 64v to 69v (as long its under diode spec) These diodes are just noise barriers between the both side of the diode.
                  • howardc64
                    • Jun 2017
                    • 590
                    Probed all pins between PSU and LED driver board
                    pin 4 = Vdrv On = 3.067v
                    pin 7,8,15,16,20,21,22 = GND = -0.011v
                    pin 9,10,11,12,13,14 = Vdrv = 69v
                    pin 17 = B13V = 12.83v
                    pin 19 = FB = 2.139v
                    FB signal looks like goes through side B of the LV358G op amp (IC 280), then to the main board connector (CN 250) and the Samsung chip nearest that connector (IC 2100)
                    • lotas
                      • Jan 2016
                      • 4554
                      • Russia
                      #30
                      As the LED degrades, voltage increases, which in turn leads to increased current and heat generation. This is due to the deterioration of the semiconductor material, which means that higher voltage is required to maintain the same brightness. Increased current and temperature accelerate further degradation of the LED, creating a "snowball" effect.
                      Degradation and Voltage Rise:
                      As an LED ages, its internal resistance increases. This means that more voltage is required to pass the same current as it did at the beginning.
                      This is what is happening with you, what is written on the power supply, the output voltage, has now increased and over time it will gradually grow.
                      • howardc64
                        • Jun 2017
                        • 590
                        very good summary. Another variable is any high heat solder connections thermal cycle weakening over time. I fixed about 20 apple 27 thunderbolt displays by reflowing ithe edge lit LED bar connector. Original lead free solder weakened and resistance increase push PSU beyond its limits. On this TV I haven’t disassembled to know what the led system looks like.
                        I guess Samsung firmware updates (default auto update) made it much worse by disabling dimming or even any ability to adjust backlight to lower brightness.
                        • howardc64
                          • Jun 2017
                          • 590
                          An update on this Samsung local dimming LED TV. Newer firmware from last 2+ years ruins the TV's picture quality. Can't go back to older firmware and can only repair by getting older firmware main board.
                          After I fixed the shorted PSU and turned on the backlight. TV is on latest firmware (1661) Picture brightness doesn't work (on full bright) and local dimming zones not working. This is a common problem for this TV in this Samsung support forum thread ( link ) Samsung fixed OP TV by replacing main with older firmware main.
                          shopjimmy had a complete board set (main+PSU+LED driver+wifi) for $105 including tax + shipping with 10% coupon. Took a chance main board had older firmware, installed the board set and TV works great (brightness + local dimming (~1000 zones!) working perfectly) Main baord firmware was 1304.1
                          Just info for anyone encountering this newer firmware problem on this TV.
                          Also Vdrv on the replacement PSU is 68v. Maybe this is the correct voltage instead of what is printed on the PSU. Maybe LED array aged with more resistance. Don't really know without original new TV reference measurement.
                          • lotas
                            • Jan 2016
                            • 4554
                            • Russia
                            #33
                            Samsung used to have service firmware with version 000.0 for different TV models, and to downgrade the firmware version, you first had to install this one, and then the one you wanted, any version.
                              • 12116
                              • U.S.
                              #34
                              Thanks for the heads up on this shit firmware update. I have to say again, SHAME on samsung.
                              • howardc64
                                • Jun 2017
                                • 590
                                Thanks for the hint. These are high end Samsung TVs (neo QLED series) and still under 3 year warranty. Most of the failure repairs are just warranteed Samsung service or refund. Samsung support said no older firmware is available and I didn't find anyone posting FW 0000.0 for this TV. Since I got the TV for free after Samsung failed repair attempt and refunded prior owner, Samsung support repair is unavailable for me.
                                Dumped the Flash ROMs on the original and replacement LED driver board (attached) to compare and has many differences. This board has complex chip including processors so I didn't dare to mix the old LED driver board with the new main board (in case firmware update update both boards for coordinated functions)
                                flash rom = Winbond 25Q32JV (4Mbyte NOR flash) on both boards
                                original board = BN9417426B
                                shopjimmy board = BN8417426A (shopjimmy product listing shows ...426B but I got ...426A. Brightness and local dimming does work)
                                Click image for larger version  Name:	IMG_4569.jpg Views:	0 Size:	4.45 MB ID:	3684978 Click image for larger version  Name:	IMG_4727.jpg Views:	0 Size:	3.59 MB ID:	3684979
                                I assume main board has flash ROMs and eMMC (but hidden under heatsink so I didn't remove and examine). Surely eMMC is updated by new firmware.
                                Click image for larger version  Name:	IMG_4725.jpg Views:	0 Size:	3.33 MB ID:	3684980 Click image for larger version  Name:	IMG_4726.jpg Views:	0 Size:	3.70 MB ID:	3684981
                                I searched for flash ROM and eMMC on LED driver and main board incase the TV can be repaired by flashing older flash contents. But it seems unlikely due to eMMC and I also have 2 different revs of the LED driver board.
                                • lotas
                                  • Jan 2016
                                  • 4554
                                  • Russia
                                  #36
                                  The firmware is located here (chips with colored dots indicate that they have been programmed and tested).
                                  • howardc64
                                    • Jun 2017
                                    • 590
                                    Thanks, I pulled dumps from the 8pin Winbond.
                                    The other chip you pointed out that is programmed is interesting. Its a Transceiver FPGA ARTIX 7 XC7A50T by AMD (orignially by Xilinx which is a major FGPA producer acquired by AMD in 2022) Device summary below (pg3) These FPGAs are designed to transmit high speed signals across long distances (a hard problem, higher the speed, more signal delay variation from wire length even board level trace lengths ) They use typical differential signaling etc. XC7A50T has 120 differential signal pairs. I guess LED dimming is probably accomplished by this signaling and must have some hardware near the LEDs to decode and finally turn into voltage/current.
                                    https://docs.amd.com/v/u/en-US/7-ser...election-guide
                                    https://www.amd.com/en/products/adap...a/artix-7.html
                                    I have background in FPGAs. Its basically programmable hardware design with a sea of programmable logic gates. In additional commonly useful hardware blocks are often included (Digital to Analog Converters, PCIe interface block, microprocessors, DSPs, etc) If Samsung firmware is updating the programmable logic gate section, it is far more complex than typical microprocessor programs. Its is now hardware logic and require very different engineering skills.
                                    Anyway, looking online for Samsung firmware 0000.0 shows a whole bunch of Samsung TV models that looses function on software updates. I guess I'll be avoiding firmware updating Samsungs in the future.
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • Hink85
                                      Samsung UN65RU8000FXZA Led Driver Board
                                      by Hink85
                                      Hi All,
                                      I picked up a Samsung UN65RU8000FXZA 4k Smart TV a few weeks ago, in hopes I could repair it and get it working. It was purchased in Nov 2019, Samsung already replaced this tv by the original purchaser.
                                      I have eliminated the main board and power supply, and back lights are working. It was cycling on and off when i got it, I disconnected ribbon cables until I pinpointed it down to an LED driver board, and with the suspect board or ribbon cable section, 3/4 of the TV will now stay on and it no longer cycles on and off. I haven't found any shorted capacitors...
                                      08-12-2020, 07:03 AM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • r38_
                                      Viewsonic VA1616W driver board burned
                                      by r38_
                                      Hi everyone, i connected my va1616w monitor to netbook and it burned components of the driver board in the vga port area, i think i bad connected the cable by mistake. After this the monitor power on but never receives signal from computer or any connected to vga port.
                                      I didn't find schematics of the driver board. Also i tried a universal lcd controller (mt6820-t) board with the panel but it was not supported. This is repairable or the board is dead? Thanks in advance. Images of the board:
                                      08-20-2022, 10:51 AM
