Panasonic DMR-EZ47VEB
  • diif
    • Feb 2014
    • 6978
    • England
    Hello, my friend has this DVD recorder that is is showing LD FVU on the display.
    This indicated that it requires a firmware upgrade. i have emailed Panasonic but have had no reply.
    i am wondering if anyone has a copy or knows where to download it.
    Thanks.
  • Ady2017
    Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
    by Ady2017
    I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
    06-06-2025, 08:05 AM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
    DVR recorder Switching power supply Failure
    When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
    Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
    This...
    05-27-2023, 03:03 AM
  • AquaMan Ua
    Problem with PANASONIC CF53 laptop after changing BIOS settings
    by AquaMan Ua
    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
    05-17-2025, 09:40 AM
