Samsung PN43E450 - Won't turn on
  • spudnik144
    • Aug 2014
    • 14
    Re: Samsung PN43E450 - Won't turn on
    Thanks Tom66, I understand what you mean now.
    By the way, here's another link to a troubleshooting document for the E450:
    ftp://helpedia.com/pub/temp/datashee...t_track_guide_[SM].pdf
    Here's a screen shot of the Power Switch connector pin function page of that document:
    • Catman5775
      • Aug 2014
      • 6
      Originally posted by Agent24
      Thank you
      • spudnik144
        • Aug 2014
        • 14
        There's a Samsung model PN51E530A3F with a cracked screen for sale not too far away from me. Would the main board work with a PN43e450?
        • spudnik144
          • Aug 2014
          • 14
          Anybody know if main board for PN51E530 is compatible with the PN43E450?
            No, it is not.
            That is a 1080p TV, yours is 720p.
            If you wanted to do a 51" 720p -> 43" 720p, that also would not work unfortunately, because the panels are different resolution (1024x768 on 43", 1365x768 on 51")
            • spudnik144
              • Aug 2014
              • 14
              OK, thanks for clarifying that tom66!
              • Asraf Atb
                by Asraf Atb
                01-27-2025, 05:02 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • Lee M.
                Samsung UN75RU8000FXZA bad main board?
                by Lee M.
                When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                11-08-2023, 07:46 PM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
              • JDC
                (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                by JDC
                ONN 100012588
                Issue: No Power, Then Rebooting After Main Board Change
                Short answer: replace main board and power board
                Technical answer: replace main board and Q306 & Q307 on power board.
                Long answer:
                TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                07-15-2022, 07:39 AM
