Philips 42pfl3606 efforts on repairing the psu
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Hello. Its been almost a month waiting for several pieces to come from ebay, several reworks made, and now i am at the point of giving up. But before i do, i need your honest opinions.
    This LCD Tv was stricken by a lightning and was totally dead when came.
    Main fuse blown.
    Checked for short in the main capacitor, OK. replaced fuse and blown again. Rectifier faulty. Changed it and the fuse.
    TV led was lit. 5V standby was ok.
    PS_ON 3.3V but no 12/24V.
    After many measurements decided to order the IC controller of this rail.
    Replaced the IC and the mosfet. 12 and 24V now are OK.
    TV working without backlight. Examined the 24pin IC of the backlight and found many shorts. Found also some traces of possible arc-ing between smd components (last pic).
    I am ready to order this IC, but now i am very pessimistic.
    I need some opinions.
    Thank you.
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Re: Philips 42pfl3606 efforts on repairing the psu
    UPDATE!
    happy to tell that: took the backlight IC from a similar lcd-faulty philips in my workshop and now it is working !!!
    Thank you for the time!
    • selldoor
      Slow Learner
      • 7870
      Good fix - your too quick I looked at your post briefly but was tired and thought Ill look at that tomorrow and here I am - too late.
      Did you resolder those joints as well?
      • senndogg
        • Dec 2011
        • 383
        • Albania
        yes, i restored the cut traces, resoldered and cleaned everything. Now its been nearly 2 hours the Tv is working well.
        • Ltank
          • Jun 2013
          • 776
          What was the IC# and actual part number for others to reference to?
          • senndogg
            • Dec 2011
            • 383
            • Albania
            The backlight IC801 is a UBA2071AT from NXP.
            The 12/24V controller is a NCP1271A from OnSemi.
            The 12/24V original mosfet which i dont remember, was changed with a Toshiba 2SK2797.
            The last 2 are bought from a well known HongKong supplier and came in 8 days.
            Anyway this scenario was provoked by a lightning, i have barely seen 24pin BL ships failing.
            • bangy
              • Mar 2016
              • Serbia
              Hi,i got almost same problem but i got only +5v everything seems good ,caps ok.
              No 12v and 24v. Tv works fine 2,3 days and after that dont work few days...
              Anybody can help me or advice
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Is this the service manual
                https://cdn.badcaps-static.com/pdfs/...e8f6774242.pdf
                If your power supply matches the one shown in section 10.2 - PSU Thriller 42" - then disconnect the power supply from the main board and short pins 10 & 11 on CN903 and check for 24V and 12V using your multimeter.
                • corrize
                  A funny fuse story – Lumix LX100 II
                  by corrize
                  Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                  I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                  The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                  There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                  And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                  10-19-2023, 09:58 AM
                • jesterace
                  Samsung UE46ES8000 Blown fuse but no other signs of short
                  by jesterace
                  Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                  09-11-2024, 03:14 PM
                • jshhh
                  Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                  by jshhh
                  Hi guys,
                  I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                  How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                  Anybody know how to remove this type of fuse?
                  (The fuse is toward the bottom of the image labeled F2)...
                  06-17-2025, 01:35 AM
                • Babbar
                  by Babbar
                  04-12-2024, 01:12 AM
                • drykid
                  Matsui 175S microwave fuse replacement
                  by drykid
                  I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                  Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                  12-21-2020, 01:15 PM
