21SF8XEL 21" CRT TV Turns off by itself
  • GraphicMan
    • Aug 2018
    • 124
    • Egypt
    Hello
    The chassis number is kd -331 (v1.0) sh12144
    Tv once plugged in it shows the red led normally, once clicked on ch+ or ch- it does show the normal blue screen with no issues, but that is when it was left for few hours Off, then shortly it goes back to sleep by itself, tries by itself to go back on but it does not and then to sleep and sometimes if i try so many times it does not even show the red led anymore unless i unplug and plug again, after the first try if i try again to turn it on it never show anything on the screen anymore, just goes to sleep
    what could be it?
    thanks
  • Ludmilaharhordina
    ACER A315-53G C5V01 LA-E892P rev2A the laptop turns on, but the display does not show
    by Ludmilaharhordina
    good afternoon.
    need help.
    the laptop turns on, but the display does not show.
    the laptop came to me from another workshop. visually broken USB 3.0 and soldered BIOS flash drive.
    I unsoldered USB 3.0 and flashed several different BIOSes, but it did not help.
    +VCC_CORE 0V
    +VCC_GT 0V
    +VCC_SA 1.03V
    +0.6VS_VTT 0.6V
    +1.0VALW_PRIM 1.0V
    +1.0V.VCCSTU 1.0V
    +VCCIO 1.OV
    +1.0VS_VCCSTG 1.0V
    +1.2V_VDDQ 1.21V
    +1.8VALW_PRIM 1.81V
    +1.8VS 1.81V
    +3VLP 3.27V
    +3VALW...
    04-02-2025, 08:51 AM
  • survivalbloke
    Lenovo Flex 5 14ITL05 - will only sleep if commanded to through start menu>power icon
    by survivalbloke
    This laptop refuses to sleep unless specifically commanded to sleep through Windows. If I close the lid, the screen does go dark just before the lid is closed, so it appears the hall sensor works. However, it will sit there, drawing 1.xx amps until the battery dies. If I command it to sleep, it drops down to normal sleeping current. If I have it sleeping with lid closed and I disconnect the power adapter, it will wake from sleep, even with the lid closed. I have updated the firmware, but still the fault persists. I've also verified power settings in Windows that the device is to sleep when the...
    03-20-2025, 02:29 PM
  • www
    LG L192WS-BN backlight turns off after 1 second
    by www
    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
    03-24-2024, 05:26 PM
  • Stefano Crivellari
    Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
    by Stefano Crivellari
    Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
    01-14-2025, 03:49 PM
  • andrhouseolly
    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
    by andrhouseolly
    Hi.
    I kindly ask you to help me solve the problem.
    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
    The board turns on, there is no image.
    Read more. When the power supply is connected, the front panel indicators light up briefly.
    When you press the power button, the button indicator lights up. The board works
    there is no image, there is no matrix initialization, there is no image on HDMI.
    When turned on, the fans do not spin, but when they warm up they start spinning.
    When you turn off the button, the fans spin up to full speed for a short...
    05-11-2024, 03:14 PM
