Panasonic TC-P54VT25 colored horizontal line issue
    Just started seeing this issue tonight.
    Is this something fixable with a little massage of the cables inside or does this need a new board?
    http://imgur.com/hcGqt1i
    Re: Panasonic TC-P54VT25 colored horizontal line issue
    definitely board issue, I've seen that before posted up on other panasonics and there's a youtube video of one. last I heard from that guy was the A board was replaced with no change.
    My first guess would be A board but these have a separate D board as well so since the A board did not fix it for the last bloke I'm leaning towards that D board.
    I've attached a test procedure, try it and see if that isolates A or D, it's definitely one of those.
    Also you'll need to check what revision boards you have as they are different for each size
      Thank you for the reply!
      After going through that procedure I believe it's the d board.
        Well that's good if it gives you a definite result, confirms my suspicion and hopefully you can find one reasonably price. Last 54VT25 I helped with was also D board with 1 blink SOS and about $100 from SJ.
        So yours should be TNPA5149AD or TXN/D1LWUUS but SJ is now out of stock
        search both numbers, I found this bargain
        http://www.ebay.com/itm/Control-Boar...3D251570519069
        http://www.ebay.com/itm/PANASONIC-TC...item20ddef32ff
          Thanks for the info!
          You listed two boards - do I need both or would either work?
          I'm not sure I want to swap the boards myself - how difficult is it to do? Is there a guide somewhere?
          Thanks for all of your help!
            They're the same board known by 2 part numbers to help you search. Should be a piece cake, should just be a matter of lifting the tabs on the ribbon connectors and gently remove the ribbon, some screws and remove. Installaion is the reverse,
            dowload the manual , http://elektrotanya.com/?q=showresul...oria=&kat2=all
            should be something in there.
              This is great - thanks so much for your help! I'll report back once I get the board and have a chance to install it.
                Reporting back - installed the replacement D board and all is fixed!
                Thanks again for the help!
                  Cool, nailed the right board first go, not too expensive either.
                    Hi Tw2005, I am experiencing the exact same problem as the poster with the exception that the on screen color bars are on the right side of my display. Am I safe using either one of those boards you linked on ebay or is it safer to take the D board out of my TV and get exact part numbers?
                      If you told us the model then we could answer this but if it's the same size as the OP the it'll be the same board or go to SJ and look up your model and have a look
                        Yes it is the same model as op. I thought I may have read somewhere that the product codes can vary and was important to check the code on the part being replaced. This may have been for another board I can't recall.
                          It is but pretty sure what 's been quoted is for a 54" but there's nothing stopping you from taking the back off and confirming what is installed and go from there.
                            Thank you. I will let everyone know if this fixed my problem as well.
                              Newbie question here and hopefully someone still reads this thread
                              I have the same issue (red and blued lines) and I am about to order the D board from eBay
                              PANASONIC TC-P54VT25 D BOARD TNPA5149AD
                              Only question I have is around the SU and SD boards. My failure is on the upper right hand quadrant when looking at the TV straight on. Should I consider looking also for the SU-board?
                              I am comfortable replacing the board and I can try the D board first and if that does not fix it, start looking for the SU board.
                              Thanks in advance
                                Thanks in advance
                                If you put a picture up it would be helpful but I'd go D board first
                                Bad su would be whole of top half issue.
                                  Thank you very much TW
                                  Picture attached
                                  Just ordered the board on eBay and I'll follow-up on results.
                                  Thanks again
                                    Awesome work
                                      Picture attached
                                      Thanks again
                                      Won't need any buffer board for that. Should be D board otherwise A is only one left if it still is there
                                        Just to confirm, replacing the D BOARD TNPA5149AD fixed the issue of red and blued lines on my PANASONIC TC-P54VT25
                                        Not a bad $75 buy from eBay
                                        Most importantly, thanks TW for the guidance.
