I picked up a 55" Element dead after a lightning strike. Strike also took out Cable Box. Basic troubleshooting shows that it has the 5vds and when I hit the power button (blue light blinks) I have all correct power on the power supply including the 24vdc feeding the 1 master and 3 slv inverter boards. The backlights will not come on though. I have looked at it with a flashlight and do not see an image on the panel. Ihave checked all the fuses on the Main, TCON and inverters all test 0.2 ohms
Element ELDFT551 not turning on
Re: Element ELDFT551 not turning on
Follow-up... I was able to force the backlight but no video or menu. The attached picture is how I forced the backlights on. I'm thinking Mainboard is done.Attached Filesif you find these attachements useful please consider making a small donation to the site
That means we know at least that the main board is not sending the BL_ON to the inverter board, so yeah, sounds like the main board is not working.Never stop learning
by flyskyThere is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.
by EasyGoing1I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
This is the general setup that I have now.
This is what the... -
by sam_sam_samI was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap... -
by wwbielskoHi,
one sms element is missing at touchpad pcb in Macbook A1707
Could anyone identify it ? Smd element is pointed on pictures
thanks... -
by sirpsycholWhile recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
... - Loading...
