TV Power Supply Unit
  • Markus1
    • Jul 2013
    • 80
    Re: TV Power Supply Unit
    Originally posted by budm
    At 11.5V on VDD pin 9the startup cap is charged up through the internal current source, that is below the startup voltage requirement which is around 14.5VDC.
    Page 6/20 of the spec sheet I provided: It is good to read the description on how the IC works.
    I did go through it. I think I've got an overall understanding of its working. So the voltage (11.5V) comes from internal current source connected to the Drain. Its level is monitored against the two thresholds:
    VDDon to start switching and turning off the internal startup current source,
    VDDoff to stop switching and turning on the internal startup source.
    And it continues. Feed back from the Opt-isol provides regulation.
    So the startup cap connected to the VDD pin may have leakage resistance or the internal current source inside the IC is bad.
    I will go with the replacement of the cap C126, and also another one added to pin 4 as per modification (mentioned in earlier post). If no improvement I will try to replace the chip (IC103 Viper22A).
    Will report on Monday.
    • Markus1
      • Jul 2013
      • 80
      Good news. TV is up and running.
      Total of 3 caps in the start-up circuit were replaced: C127 47uF, C126 47uF (refer attached circuit diagram), and also a 22 uF cap (part of modification to the board, not shown on the diagram). All caps rated at 50V.
      It appears that the 22uF cap was the culprit. It was inserted (as part of the modification) between pin 4 of the IC103 and Gnd. I do not have an ESR meter but when measured with a capacitance meter this cap has shown only about 10 uF.
      After these 3 replacements the old TV came alive and is doing well.
      Big thank you to all who responded to my post, and to selldoor and budm in particular. Your advice, instructions and directions for proper diagnostic procedure was much appreciated. It is a fantastic forum with great expertise and also willingness to share the knowledge and to help not only seasoned TV technicians but electronic enthusiast as well. I look forward to a next project.
        Thanks for the good news and the repair follow-up, now when you look at the SMPS ICs, they basically operate in the same principle, and if you can get the spec sheet it will help a lot since the circuits in the application notes will be real close to what you have.
        • pr0cess0r
          • Jan 2011
          • 110
          Tahnk you for this post. i changed the 22uF cap and the set work. Its wont always turn on so i will change all caps now that i know it good!
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
          • Gjackson
            Air-conditioning unit power supply failing to power up
            by Gjackson
            Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
            01-08-2022, 09:24 AM
