Technica M32/57G
    • 31020
    Re: Technica M32/57G
    if they are startup caps, use 47uf instead.
    • sordids999
      • May 2013
      • 2152
      https://www.youtube.com/watch?v=8lKA...jPdt2RIDn6h67A
      ok so turned the tv on this morning all good until i noticed some distortion in colours,i have tried to upload a video to show this so im gathering possible tcon board fault ?
      • sordids999
        • May 2013
        • 2152
        very strange tried the hdmi lead all good then tried the scart again all working fine ?
          LVDS cable clean and seated both ends? Maybe cold solder joint under processor... Probably not T-con board IMHO...
          • sordids999
            • May 2013
            • 2152
            ok tv yet again is dead all voltages fluctuating shall i change the last 2 caps (due to being from a old board) with 47uf 50v due to running out of stock with the 22uf 50v caps
              • 31020
              i say yes.
              back when i was doing satellite recievers almost production line style,
              we always bumped up the startup cap to the next value.
              the plus is it lasts MUCH longer before failing.
              the downside on paper is it takes longer to build the initial charge for starting.
              i say "on paper" because we are talking fractions of a second - so who cares!
              • sordids999
                • May 2013
                • 2152
                #27
                ok thanks already done this so i changed the two old 22uf 50v caps with new 47uf 50v and now the tv is working again but im still suspecting a fault elsewhere with the psu but ill keep testing
                thanks
                  Maybe a cold joint?
                  • sordids999
                    • May 2013
                    • 2152
                    #29
                    yeah thats what im thinking tom ill run it for a few days then see how it goes,if it goes again then ill check for cold joints
                    • sordids999
                      • May 2013
                      • 2152
                      #30
                      Ok just a quick update left tv off since yesterday so turned it on this morning still working fine so fingers crossed
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                      • fharris1977
                        Vizio D50u-D1 Dead Set No Standby
                        by fharris1977
                        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                        12-28-2023, 10:25 AM
                      • Crystaleyes
                        Samsung BN44-00259A standby question
                        by Crystaleyes
                        Hi all.
                        I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                        SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                        Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                        The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                        08-11-2023, 05:15 AM
                      • psssst
                        Yamaha TSX 120 Standby Problem
                        by psssst
                        Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                        03-01-2024, 07:25 AM
                      • reessi
                        JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                        by reessi
                        I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                        You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                        Years ago it had some bulging caps...
                        04-26-2021, 11:42 AM
