Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
  • alltvrepairs
    • Jan 2014
    • 224
    • Malta
    I have confirmed that I have a mainboard problem.
    I have tracked no hardware issued on board so might be a software dump required.
    I have searched a bit but wasn't able to find anything for my screen:
    Here are some more details:
    Panel: cy-nn065hgev1h
    Main: BN94-14180M P08F
    Your help much appreciated!
  • Diah
    • Feb 2013
    • 6376
    make jumbers between this 2 points feedback FB, then disconnect one LVDS at time.... see which half of screen will show image
    • alltvrepairs
      • Jan 2014
      • 224
      • Malta
      Have checked these points before and with both LVDS disconnected there was 3.3v and 0v,
      However I have tried 2 other boards similar but different BN94 number and got a picture. 1 perfect pic (From UE55MU6400) and 1 almost B/W with lines.
      Got the Panel no from Service Mode for the good picture board and tried to update the second (B/W pic) board as its identical board but didn't find a matching model out of all those different displays in SM.
      • alltvrepairs
        • Jan 2014
        • 224
        • Malta
        Anyone has the correct spi dump for this board?
        Thanks!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4343
          • Italy - Milan
          Working software and no output video tends to be bad tcon integrated to main board.. maybe the data on the tcon spi eprom, you can import that one on the board that displays ok
          • alltvrepairs
            • Jan 2014
            • 224
            • Malta
            Hi, interesting as didn't know about this trick. Did this but with both connectors out and points shorted, the tv start rebooting sequence. Trying each lvds makes no difference.
            I have swapped ic1603 ic1604 with a working but wrong panel board but still same problem.
            The tcon is part of the cpu so no more places to look at. I have just ordered a replacement board with same specs and display.
            I have managed to get the dumps for both ICs. Will post them later in the correct section.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4343
              • Italy - Milan
              no software issue then, short circuit in tcon power supply circuits, maybe a small cap, you can test also mosfets & diodes
              • alltvrepairs
                • Jan 2014
                • 224
                • Malta
                For curiosity, do you still remove the EEprom / SPI chips from main board to read / write? With closeby SMDs sometimes becomes a bit risky job. I am aware that the programmer cannot power supply the whole board.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4343
                  • Italy - Milan
                  i .always try to read with clip, in certain situations it does not go, but it's mandatory a verify after.
                  • Asraf Atb
                    by Asraf Atb
                    01-27-2025, 05:02 PM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • Lee M.
                    Samsung UN75RU8000FXZA bad main board?
                    by Lee M.
                    When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                    11-08-2023, 07:46 PM
                  • valvashon
                    Samsung UN55FH6030CXZA main board USB jack indentification
                    by valvashon
                    Samsung UN55FH6030CXZA main board, BN41-01894, bad USB jack. Jack is mangled and needs replacing with like. Jack is marked "Simula" with the number 130318. Search for Simula turns up a weak looking website of a company that seems/seemed to supply USB jacks and other USB technology but no current items turn up for sale.
                    I should be able to research and find something applicable through a Digi-Key search after I unsolder/cut out this one and measure the mounting/pin connection pattern on the board but I thought I'd ask here to see if anybody knows of an exact make/model...
                    01-23-2025, 11:17 AM
