Panasonic TC-P50S2 No Audio
  • Gadjet
    • Aug 2012
    • 248
    Sound went out a few days ago, tried using a sound bar but still nothing. Was thinking something must be wrong with the main board. Any ideas?
  • Gadjet
    • Aug 2012
    • 248
    Re: Panasonic TC-P50S2 No Audio
    This tread is closed...issue was the cable box.
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • i_am_patch
      Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
      by i_am_patch
      Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
      04-30-2024, 08:20 PM
    • Piaskos
      Dell Vostro 5490 - no sound, no audio device
      by Piaskos
      Hi, i've got problem with Dell Vostro 5490.
      Board - Mantis CML 18788-1
      Windows says "no audio device detected". The other functions work properly.
      What i've done:
      1. I checked motherboard
      2. I changed audio codec (ALC3204)
      3. I reflashed bios with clear ME
      4. Audio is enable in bios
      5. Both speakers are good
      6. After installing the drivers from the Dell website, the devices visible in the manager:
      - Audio for intel displays
      - Intel Smart Sound Technology...
      01-30-2023, 02:58 AM
    • hugocarmo
      Panasonic TX-24A1UN CRT Sound and Input problem.
      by hugocarmo
      Hi.
      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
      It is imaculate inside, almost no dust or debris inside.
      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
      So I started to look for a service manual, I found one, and started from the beginning.
      Most of the times the caps are the problem so I orderer all the caps for all boards,...
      04-26-2025, 07:45 PM
    • CapLeaker
      Motorola Minitor V pager no audio / sound repair
      by CapLeaker
      Got a bunch of Motorola Minitor V pagers from Fire Departments here trying to fix some out of the non working ones. These pagers are known for either no sound / audio or they don’t charge. The internet is full of suggestions like metal shavings inside the speaker?
      Anyway so I took one of the Minitor’s apart for my amusement in order to see why that is and nobody can fix em. There are no service manuals or schematics for these that I know of. However… I did find the problem!
      On the main board of this unit where the speaker connects to there is a metal shield....
      06-10-2025, 07:44 PM
