Samsung ln40a530p1fxza Loud screeching noise no screen
  • gringoboy6
    • Jul 2014
    • 19
    • usa
    Hello Everyone,
    I am new to this forum and the world of electronic repairs lol. My nephews tv is down and im trying to be the hero of the day.
    The tv does not not turn on and only has the standby light on. I was told before it completely shut down it use to come on and the screen would look "crazy" and make a loud high pitch screeching noise then shut off .
    So far I -
    looked at the caps none are bulging
    disconnected the tcon from motherboard and nothing
    I jumped the powersupply with pin 1-3 and 1-5 and the back lights came on and stayed on
    I read that it could be the main boards graphic card so I "Baked" the card in the oven for 8 min at 400 degrees to reflow it. after i let it cool down i put it back in and the tv came on and i went to the menu screen but then it shut off again and shortly after it turned off i heard a click for the first time as well
    Any help is much appreciated thank you.
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung ln40a530p1fxza Loud screeching noise no screen
    Mainboard issue, I have one that does this. It would turn on the screen would be all scrambled, it would turn off and back on and squeal out of the speakers with a normal picture. It would turn off and back on a few times then be normal.
    Fixing the caps on PS did help it but it still does the squeal and scramble upon the first power up if it has sat for awhile.
    I am pretty sure its the same unit as the one you have listed too.
    I have seen this affliction on a few Samsung panels.
    • gringoboy6
      • Jul 2014
      • 19
      • usa
      Is there any way to fix this without ordering a new main board?
      • gringoboy6
        • Jul 2014
        • 19
        • usa
        bump
        • gringoboy6
          • Jul 2014
          • 19
          • usa
          Hello can you guys help or confirm the main board is doa ? lol i don't mind getting my hands dirty
          • Shinju
            • Mar 2014
            • 1239
            I am not sure how you would go about testing CPU issues, if the mainboard is less then cost of a new tv I would do that.
            I don't think you can really fix the issue with out some serious tools like a O-scope, hot pad and extensive surface mount soldiering.
            I left mine as is because it works if used regularly if i leave it off for more then a day or two it acts up on power up but is fine after that.
            • gringoboy6
              • Jul 2014
              • 19
              • usa
              You said that you changed the caps on the psu were yours bulging?
              • Shinju
                • Mar 2014
                • 1239
                2 out of the 6 1000uf caps were bleeding out of the top. I replaced them all.
                Take the back off you set and snap some photos of each of the boards as clear as you can.
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  can you post close up photos of the main board (back and front)? Since this is LCD I'm not certain if this is the same main board such as the ones in the plasmas where there's one ceramic cap that causes the screeching problem.
                  • Shinju
                    • Mar 2014
                    • 1239
                    Squeal coming out if the audio speakers or something else? Mine is coming out if the audio curcuit when the unit powers on after it's been off for awhile.
                    • gringoboy6
                      • Jul 2014
                      • 19
                      • usa
                      Okay here are the pics let me know if you need a more clear image or closer shot i added the psu as well. The sound is coming from the speakers at least what I think. It has only made the sound 2 times since i have been working on it.
                        What is the power supply P/N? BN44-??????
                        • gringoboy6
                          • Jul 2014
                          • 19
                          • usa
                          bn44-00197
                          • gringoboy6
                            • Jul 2014
                            • 19
                            • usa
                            I have to tuck in for the night lol so ill be back on tomorrow to check out your response thank you for your time
                              Is it 197A or 197B, tom66 has the diagram for your board.
                              http://www.toms-service-manuals.com/
                              • gringoboy6
                                • Jul 2014
                                • 19
                                • usa
                                It's a
                                I see it what do I do next ?
                                  I already exceed the download limit today from his site, so is it A or B?
                                  • gringoboy6
                                    • Jul 2014
                                    • 19
                                    • usa
                                    It's A
                                      OK good, I download both A and B earlier. So let me look at the diagram.
                                        OK report the DC Voltage readings on each pin of CN801 when TV is OFF and when TV is ON.
                                        for example:
                                        pin 1 Power ON/OFF = xxV (OFF), xxV (ON)
                                        I believe you have main board problem.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
