42PFL7403D/10 stuck in upgrade menu
  • torentino
    • Feb 2014
    • 22
    • Slovenia
    after the PSU repair was jerking around the service menu and stupidly activate mpeg4 option in non mpeg4 set. Tv was contionusly rebooting, UART says error 38 or 39 IC2 bus Tuner. Starting the upgrade procedure with latest FW, but stops with error.(dozen of tries)
    Now stuck in upgrade procedure. Somewhere on net Ifind, that the thing can be repaired with NVM editor, but have no idea, how and with what.
    Any idea anybody?
    LCD LED TV Service Menu Codes
    TCL LED TV Service Menu Code
    LG LED TV Service Menu Code
    10-31-2024, 03:58 AM
  • B83C
    HP elitebook x360 1040 G5 Stuck at 'Entering setup menu...'
    by B83C
    Received a faulty HP elitebook from my friend that does not boot up properly. The internal display is broken, so the only way to view the display output is via hdmi. However, when booted up the screen get stuck with 'Entering setup menu...' when esc is pressed upon booting. HP logo isn't displayed on bootup, only black screen, but an underscore cursor appear on top left corner of the screen. Has anyone any idea what could be the culprit here? I have flashed both the EC and BIOS flash but to no avail. The serial number is 5CG9377GCT, and below is the original flash content:
    Also the...
    02-03-2025, 08:28 PM
  • netgearnetgear
    JVC 40" LED TV (LT-40KC385) - Turning ON sometimes (stuck on loading, menu etc.)
    by netgearnetgear
    Hello esteem members,
    I have a JVC Television that fails to turn ON sometimes. The stand-by red light is always on. When the TV turns on the the JVC logo displays then the TV attempts to scan for local channels...it then freezes. If I unplug it, then it refuses to turn on - stand by light on. The power supply input voltages are present - 12V, with the backlight 0.32V when the TV refuses to turn on. Backlight voltage is 2.98V when TV does turns ON. All regulator chip has 3.3V on pin 8. Processor voltage - 1.02V, Ram - 1.5V. I am thinking about reflowing the on-board RAM. When the TV was...
    10-28-2023, 06:59 PM
  • stormanimal83
    Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
    by stormanimal83
    Hey....
    Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
    my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i canΒ΄t understand...
    01-18-2024, 02:15 PM
  • claws77
    FX553VE-DM318T(FX553v) not POSTING
    by claws77
    Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
    Gpu - nvidia geforce 1050ti
    Ssd orion o700
    Hdd hgst721010A9e630
    See images
    What's not working right?
    The system does not even POST, display is black,
    LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
    When did the problem happen?
    My laptop had dual boot setup, ubuntu and windows 10.
    It already had a moklist error, that would occur when i tried to boot ubuntu.
    05-17-2025, 04:09 PM
