Sony kd 43x85k no power at all - not even the click for power.
  • lfhlaw
    • Mar 2014
    • 115
    I got this Sony KD 43X85K TV. It will not power on, No LED light in front.
    1) I did check for blown Capacitors and I didn't see any bulging Capacitors, but that doesn't always mean there isn't a bad one present.
    2) I was going to check voltages at the pins and I did get some voltage, but got confused as there are 14 pins, but the descriptor on the left of the pin connections has only 9.
    Voltages i did get were a 3v which is usually stand-by power IIRC, and 2 pins had 13v and I was reading similar voltages to the main board. But unless I'm able to figure which pin is which, it makes assessing more difficult i think.
    Or is there a different component I should be looking at?
    Thoughts?
  • Diah
    • Feb 2013
    • 6438
    on the right side of the socket you have the reset of Pins GND t-con_on and T-CON VCC 12V .. and 12V
    so do the messing again over all and listed here the messing by Pins number
    • lfhlaw
      • Mar 2014
      • 115
      Ok so for the 14 pins, from bottom to top based on the picture.
      pin voltage
      1 0.11 v
      2 NC
      3 NC
      4 NC
      5 NC
      6 12.6V
      7 12.6 V
      8 12.6 V
      9 NC
      10 NC
      11 3 V
      12 NC
      13 NC
      14 NC
      • Diah
        • Feb 2013
        • 6438
        you still reading the Pins on socket in wrong way. the socket had 2 row pins
        Code:
        row 1                            row 2
        1 - BLINKING                             2- PWM1_DIMMER
        3- DC_DIMMER                          4- NC
        5- NC                                         6- NC
        7- BL_ON                                   8- BL_ERR
        9- POWER_ON                          10- GND
        11- GND                                     12- GND
        13- REG 12V                              14- REG 12V
        15- REG 12V                              16- REG 12V
        17- REG 12V                              18- REG 12V
        19- GND                                     20- GND
        21- GND                                     22- GND
        23- GND                                     24-GND
        25- TCON VCC 12V                     26-TCON_ON
        27- TCON VCC 12V                     28- TCON_VCC 12V
        we are interesting on PIN messing
        7 , 8, 9, (13,14,15,16,17,18) , 26, ( 25,27,28 )
        however you wrote you have 12V but we dont know if this REG 12V or TCON VCC, at the end i suspect MB... but you can try always disconnect the screen totally from the T-CON , if the TV work you will have the audio Optic Port öit red.
        • lfhlaw
          • Mar 2014
          • 115
          So I did attempt to check more of the pins, but with the connector out of the socket. (multimeter set to 20 v max)
          The bottom row from the left to right, the 5th,6th, 7th pins only had 0.14, 0.15, 0.17 volts. (not sure on the orientation and pin numbering of the socket) everything else was NC.
          I believe I was testing the correct pins now?
          I also disconnected the panel from the T-con, connected the main board to the power board, attempted to turned power on, and the Main board optical port didn't light up.
          • Diah
            • Feb 2013
            • 6438
            so the sockets pins Numbers calculated, you need the PSU connected to MB, and flip the PSU to measure the V from downside , mark first on backside pins 1 and 2 as it show here they start messing
            Click image for larger version  Name:	IMG_8311.jpg Views:	0 Size:	714.6 KB ID:	3625573
            • lfhlaw
              • Mar 2014
              • 115
              Ok. Will do that, but as I work. This part may take me a bit longer to get to. Maybe Friday Evening for me.
              • lfhlaw
                • Mar 2014
                • 115
                So I was able to do the voltages now, correctly I believe LOL.
                I have uploaded pictures on the back...and I haven't done any soldering of any sort.
                • lfhlaw
                  • Mar 2014
                  • 115
                  So the Tcon pins are negligble, does it mean the Tcon is bad, or the powerboard? I did plug the Panel back into the T-con. just to make sure that didn't effect t he testing.
                  Also, pin 8 has power and that means BL err Or does that mean that pin 7 isn't on?
                  pin 9 has the requisite power on I'm assuming.
                  • tiki66
                    • Jul 2016
                    • 54
                    • Croatia
                    It's a new tv and it's a Sony so don't expect bad capacitors. Since you have 12V going to main board it's probably main board fault. If it wasn't, it would probably give error code (red light blinking). You can try factory reset (press power button on TV while plugging it into socket), and eventually you can try software update from usb stick, but it probably won't start if it's completely dead.
                    • lfhlaw
                      • Mar 2014
                      • 115
                      So replacement of the main board, brought the TV back to Life. Got a complete set of boards, but only replaced the main board for a cheap $25.
                      • PopsCaps
                        Sony Bravia KDL-40V2500 that will not power on
                        by PopsCaps
                        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                        I do not hear any sound and I cannot see any backlight.
                        I have tried disconnecting every cable on each board one at a time to see if anything changes.
                        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                        03-25-2025, 11:23 AM
                      • Capacitorial
                        Powersupply has all the voltages - Monitor still no power
                        by Capacitorial
                        Hello guys,
                        I have a Philips 240B7QPJEB. The monitor seems completely dead.
                        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                        The weird thing is, that the Power LED is powered over the TCON board.
                        On The TCON...
                        12-28-2024, 02:12 PM
                      • phuzzyday
                        Sony 70" 70X690E - It's now a divorce risk! (6 Months on kitchen table.) New power board installed! STILL trouble!?!?
                        by phuzzyday
                        For masochists who want to see some of the crap that I have been through already... (Truly optional now though, all those trees were barked up for no reason.)
                        https://www.badcaps.net/forum/troubl...klight-circuit
                        I started a new thread to get a fresher look at things, even with eyes that looked before. It's different now!
                        So I got this on Facebook for $66US, blank screen. Just reseated all...
                        09-08-2025, 05:53 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
