tv dump questions part 1
  • crdz66
    • Nov 2012
    • 242
    Hi everyone.
    I don't have too much experience on electronics.
    I'm a amateur.
    But is better if somebody give right answers to die trying
    1. Can I check a electrolyte capacitor (basic the main one) with the tv in on? and what voltages expect on standby mode and power on?
    2. When you check a transistor need to be the tv in on or off ?
    3. When you check you power board and make short between vs and ground, how many ohms need to be consider for detect if my board have a short.?
    4. how turn on power board on plasma tv with ps_on, standby, ground, vs_on?
    5. the 5v standby is generate after main capacitor?
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: tv dump questions part 1
    1=167 volt DC on main filter cap in standby,around 394volt DC when PSU is active(depends on make/model if there is voltage yes/no)
    2=TV needs to be off and unplugged
    3=mega ohms when healthy,better ask resistance between Vs/Va and GND on X and Y board
    4=Depends on make/model of TV,state your Tv brand and model(pictures a BIG plus)
    5=On most LCD TV's yes,on plasma depends on make/model(see #4)
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • crdz66
      • Nov 2012
      • 242
      Thanks Martino
      Big Help.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • Cvrado
        Led TV Board Replacement, same part number and model, different size
        by Cvrado
        Hello my friends!
        I have a question that I think you can answer and help me with!
        I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
        So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
        My concern is that the board won't draw enough voltage to the bac...
        03-02-2024, 05:05 PM
      • gigi3
        Dell 7320 questions regading bios dump and patch
        by gigi3
        Hi there everyone!
        I am awaiting on a CH341 programmer and a WSON 6x5 probe to dump the flash of a Dell 7320 8FC8 with Winbond 25R256JVEN chip, in the meantime I'd like to get things ready in order to maximise my chances of success. I have seen a few tools around, NeoProgrammer, Universal BIOS Backup ToolKit, CH341A Programmer, Flashrom to name some. Which one is the most recommended/suitable for this kid of application? The only one that seems to have support is NeoProgrammer New Update V2.2.0.10.
        I find my self a bit confused, and I would rather getting a clean dump...
        09-09-2025, 01:53 AM
