lg power supply keepsblowing the internal fuse
  • cossiejay
    • Nov 2010
    • 83
    any help from you wise and wonderfull guys please I have a lg tv that keeps blowing the internel fuse the model is a lg 32ls570t 16 months old the power board is a lg p/n eay62512401
    pcb:eax64310001(1.7) when the fuse is replaced and tv main lead attached fuse blow straight away please help thanks in advance
  • Engineersfoot
    • Feb 2014
    • 24
    • Mexico
    Re: lg power supply keepsblowing the internal fuse
    Check main rectifier.
    • cossiejay
      • Nov 2010
      • 83
      thanks could you tell me what it looks like I no capacitors risistors it sparks from a round dics tyre of thing near the fuse
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Sounds like you really know what you are doing - can you update your profile with country and mains voltage so we dont blow you up
        A good clear picture of the power board wouldnt go amiss as we are going to have to point components out.
        try googling Thermistor if its a green disk and bridge rectifier for later
        • cossiejay
          • Nov 2010
          • 83
          sorry I am in the uk (burnley Lancashire) and 240 volts
            • 31285
            not anymore,
            when you go into a 240v psu you deal with 365v dc
            • Engineersfoot
              • Feb 2014
              • 24
              • Mexico
              The bridge rectifier should be mounted on a heat sink. It looks like a black rectangle orientated horizontally with 4 legs. Is usually located near where the AC line comes in.
              If you're seeing sparks from a disc, as mentioned earlier, that might be a thermistor or something similar. What is the part number silk screened onto the circuit board below that part? For example "C705".
              • munirutech
                • Oct 2013
                • 72
                • Ghana
                dont forget you are dealing with high voltage, you should be very careful and you should know how to use ELECTRONICS METER to test such component
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  03-31-2024, 02:12 PM
                  07-01-2024, 06:34 AM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
                • Babbar
                  by Babbar
                  04-12-2024, 01:12 AM
