samsung 50" PN50C450B1D vertical lines
  • jose6326
    • May 2013
    • 707
    how are you doing guys
    should I buy this tv?
    it has vertical lines
    I believe it has something to do with the logic board
    but I haven't had time to search on this wonderful forum.
    I am in training all day today
    thanks for the help
  • freakaftr8
    • Oct 2012
    • 3743
    Re: samsung 50" PN50C450B1D vertical lines
    That unfortunately is a defective panel. It happens to these newer samsung plasma screens. It's the vertical ic's embedded in the ribbon cables giving up due to overheating and poor cooling. There's no fix. And fooling with them will only make matters worse.
    • jose6326
      • May 2013
      • 707
      thanks for the help
      I will see if the guy will give it to me for $10 bucks and I will sell the boards
      • freakaftr8
        • Oct 2012
        • 3743
        Best of luck.
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
        • polaro
          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
          by polaro
          Greetings,
          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
          08-27-2022, 08:46 AM
          09-07-2024, 05:50 AM
