LG plasma logic board blink code
  • tw2005
    • Oct 2011
    • 6458
    Re: LG plasma logic board blink code
    Originally posted by chood2
    I have a faulty, but not shorted YSUS. Caps look good... Not bulging... Buzzing however is quite present.
    I don't see where it shows what voltages VSETUP and VY, etc should be? I have oscilloscopes, etc.
    Label should be on the panel at the top. In my case I had an open cct transformer but that's a 2010 model. I know the same transformer was also on the 60" models too and I've also had a 60pk series also that had me stumped for a bit with that.
    • Poor Flick
      Of sound mind
      • Jun 2014
      • 3167
      • U.S.S.A. The flophouse of the world.
      Originally posted by tw2005
      OMG, as soon as I read you removed the bottom heatsink I stopped. I feel your pain. Did that some years ago myself on a Samsung destroying a perfectly good panel.
      Yep, my ass is still bruised from the ass kicking I gave myself!
      The blinking pattern on the fully repaired and normal working set is steady with no irregular pattern.
      From my favoritest movie ever!:
      Cledus Snow: Can I ask you a question?
      Bo Darville: Sure, ask me what?
      Cleedus: What the Hell do we want to go to Texas for and haul beer back here? What is that?
      Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money.
      • chood2
        • Oct 2017
        • 11
        Could you elaborate on your open cct transformer??
        Thanks for the help.
        • chood2
          • Oct 2017
          • 11
          Originally posted by Poor Flick
          Chood2, I got your email but I thought I'd post the reply here, maybe it will help others also.
          I never found an answer to my flash code. What did happen is that I replaced the power supply board and got my panel to come mostly on with no sound. Replacing the logic board got my sound on. In the process I didn't see a defect in the end of a ribbon connector, causing the blank spot in my panel. I continued troubleshooting by pulling off the skinny long metal cover on top of the ICs along the bottom of the panel thinking I would test for power on the boards. What I didn't know was the metal cover is a heat sink and when I powered it up to do voltage checks, the ICs overheated and my panel was then junk. At the time my TV had a few weeks of warranty left and after a honest talk with a repair shop, I got a new panel installed for almost free.
          Closer inspection of things showed a tiny burnt hole in a chip on the logic board, I never could figure out why my power supply was bad.
          This was my first try at fixing a TV.
          Thanks for the updates. I really appreciate this! Going to trek forward and try to find something wrong with the board I can fix...
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            by ohren
            09-08-2023, 05:24 PM
          • Yanleb
            LG 60PK550 Logic Control Board EBR63450301
            by Yanleb
            Hi all, I just want to share the repair of my 60PK550-UA TV set.
            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
            C57: 3.30V
            C61:...
            07-20-2023, 12:38 AM
          • korben_dallas
            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
            by korben_dallas
            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
            MY QUESTION:
            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
            02-14-2024, 12:23 AM
