need help troubleshooting lg plasma
  • FrenchConnection67
    • Jul 2014
    • 15
    • england
    I would appreciate some help for troubleshooting my plasma lg 42gt45.
    Please see what i ve tested so far below:
    Fault symptoms: power supply shuts down instantly after turning on the tv.
    Tests:
    1. Checked my psu output with everything connected none
    2. Disconnected the z sus and tried, fault remains the same
    3. Disconnected the y sus and tried, tv turns on, main board lights turns on, vs and va outputs are good for about 10-15s and then goes dead but tv stays on. Now i am wondering whther it is not normal for the vs and va to go dead after the logic board not getting any feedback from the x and z sus board ??????
    3. Funny enough, when i unplugg the ribbon between logic and y sus, i can reconnect the y sus to the psu with just the z sus disconne ted and the tv turn ons
    I am now a bit confused but my primary doubts are on the y suz board
    What do you think?
    Re: need help troubleshooting lg plasma
    Are you sure about that model number?
    On some LG plasmas, the Vs and Va are shut down a few seconds after the sustain boards do not output a "go" signal.
      • Jul 2014
      • 15
      • england
      Hi tom, the model nunber is 42pt85 sorry my mistake.
        Using an ohmmeter, test across the Vs on the Y-sustain. Power MUST be unplugged from the Y-sustain board! Hold the reading until it appears to stabilise.
          • Jul 2014
          • 15
          • england
          i ve just measured between the two vs pins on y sustain board and it reads 0.02 ohm.
            That would indicate the Y-sustain has a dead short on it.
            The most common fault is the IPM pack on it. However this is extremely difficult to replace unless you have a very good soldering iron and the skill to use it. (Min about 70W.)
            An alternative is to replace the Y-sustain or get it repaired. Cheapest I see for a new board is £54
            http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
            I can't see any repair services but the repair is identical to the 42X2/X3 panels which have a lot of Y-sustain failures. (The 42X4A IPMs rarely fail.)
              • Jul 2014
              • 15
              • england
              yeah i ve also seen that y sustain board for 54 pounds. a bit expensive like, but i ve also seen a a ipm repair kit for 24 pounds which might be the solution. i have three different soldering irons but not that powerful, i have soldering gun though and this is very powerful however not that precise due to its big tip. i ll find a way anyway.
              but you know i ve also measured between the two vs on the psu and got the same value 0.02 ohms (disconnected from the y sus), is that normal?
                For the PSU you will need to hold the reading for some time and wait for it to settle.
                  • Jul 2014
                  • 15
                  • england
                  i ve hold my measures for at least 1 minute and it reads 0.2 ohms same as on the y sus board (said 0.02 before but misspelled it).
                    Is the same present on the power board?
                      • Jul 2014
                      • 15
                      • england
                      yes i read 0.2 ohms across the two vs pins on both boards being not connected toguether. why? what kind of reading should we roughly get? are they not connected toguether as they supply the same voltage?
                        Ugh, sorry. I misread you, I thought you meant Vs and GND. That is fine, yes all the Vs are connected together. (This is true on virtually every plasma TV.)
                          • Jul 2014
                          • 15
                          • england
                          so i ve measured again but now from gnd and vs and get a normal reading, no continuity (on both boards)
                          any other test i could do to isolate whether it is really the y main and not the x main causing the problem. Because how do you explain that when i disconnect the ribbon cable between the logic board and the y main, the tv turns on with the y main connected but not with the x main?
                          but when the ribbon is connected, none of the board are allowing the tv to turn on?????? confused there
                            • Jul 2014
                            • 15
                            • england
                            anyone else? any ideas guys
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • Cooperr
                              Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                              by Cooperr
                              I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                              The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                              10-21-2025, 01:11 PM
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • stecos
                              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                              by stecos
                              Hi everyone!
                              I happened several times, in the search for help from the web, to consult this very interesting forum.
                              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                              Having said that I come to the gist of my post on the forum as the title suggests.
                              For my passion for technology I'm now collecting several...
                              11-28-2022, 11:39 AM
