Faulty lg 50pg3000
  • scootmansfield
    • Jul 2014
    • 28
    Faulty lg 50pg3000
    Good afternoon everyone!
    I am new to this site but from what I have seen it is a top helpful site!!
    I have a LG 50PG3000 which is around 4 years old and it has served me very well.
    I came back from a trip away the other day to find the picture acting like this:
    It is a very good TV and I would love to get it sorted.
    I have been involved with TV Aerials and Satellite systems all my working career and I think I can give it a go.
    Any ideas please?
    Scott
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Faulty lg 50pg3000
    Looks like a cracked display unfortunately. Not fixable.
    A working TV? How boring!
    • scootmansfield
      • Jul 2014
      • 28
      Someone has told me it could be a Y-SUS board, could this be possible?
        It is possible it is just a bad buffer. Very common on these sets, the buffer board is about £70 on eBay direct from LG reseller.
        I don't think it's a cracked display.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          I think i didn't read the fine print about it being a plasma - the spots look exactly like pressure marks on a LCD.
          • scootmansfield
            • Jul 2014
            • 28
            Cheers Guys for your input!
            Is there any way I can find out for definite TOM?
            Any tests I could do?
              Do you have a multimeter with a "beep" option? (When the probes are touched it beeps. May also be called continuity tester mode.)
              • scootmansfield
                • Jul 2014
                • 28
                Yes I do
                  OK, you will have to take the back cover off the TV and remove the top Y-buffer board. Carefully disconnect the panel ribbons, avoiding damaging them. (Power must be off.) Also unscrew all screws including the ones linking the board to the Y-sustain.
                  If you're not certain which board is the top Y-buffer then post a picture of the chassis and someone will highlight it.
                  • scootmansfield
                    • Jul 2014
                    • 28
                    You are very helpful thanks
                    I will get that up ASAP
                    • scootmansfield
                      • Jul 2014
                      • 28
                      Just had a look on ebay Tom as I am not back at home with the TV yet, but is this the right Buffer Board if it is that whats faulty?
                      http://www.ebay.co.uk/itm/NEW-LG-50P...item3f310feda4
                        No, sorry, that's the X-buffer which is not the one you need. You need the upper Y-buffer.
                        • scootmansfield
                          • Jul 2014
                          • 28
                          Hi Tom
                          Here is a pic of the back of the TV which part am I to look at?
                          Thank you
                          • scootmansfield
                            • Jul 2014
                            • 28
                            Hi Tom
                            https://www.dropbox.com/s/1c7xzjjvzy...716_161313.jpg
                            Thank you
                              I can't see either of those files. Try uploading them to this site directly using the Manage Attachments feature, or use a service like imgur.
                              • scootmansfield
                                • Jul 2014
                                • 28
                                Here you go Tom is that better?
                                Many thanks
                                • scootmansfield
                                  • Jul 2014
                                  • 28
                                  I AM GATHERING IT IS THIS PART?
                                  http://www.ebay.co.uk/itm/Y-SUS-BOAR...item259166987c
                                  • scootmansfield
                                    • Jul 2014
                                    • 28
                                    Tom
                                    I took off the part like you said and checked the part number on ebay and it came up with
                                    http://www.ebay.co.uk/itm/T-V-LG-YSU...item3f3866d1c2
                                    £74.50 so good advice LOL
                                    You mentioned earlier about testing it to make sure it is definitely that could you please let me know what I have to do?
                                    Many thanks
                                      That's actually the Y-sustain. In your case, you will need to replace the top Y-buffer board. If you like this can be tested for short circuits.
                                      To test, remove the top Y-buffer. It connects to the Y-sustain. You can see orange ribbons going into it. You'll need to unclip these to take out the board. (Be very careful! If you damage them they can't be replaced as they are bonded to the plasma panel.) Then -- A picture of the board and I will highlight where to test.
                                      • scootmansfield
                                        • Jul 2014
                                        • 28
                                        Morning Tom pics included I really appreciate this!
                                        • JarzabekPZ
                                          HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                                          by JarzabekPZ
                                          I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                                          08-08-2025, 03:40 AM
                                        • Spudgun
                                          Why doesn't current just bypass faulty capacitors.
                                          by Spudgun
                                          Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                                          04-01-2025, 10:33 AM
                                        • b-slayer
                                          Acer A317-53 need help to disable faulty onboard ram
                                          by b-slayer
                                          Hello.
                                          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                          - first one is to modify le bios to disable the onboard ram.
                                          - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                          so i found that my motherboard...
                                          10-12-2024, 03:46 AM
                                        • brispuss
                                          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                          by brispuss
                                          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                          12-28-2022, 02:58 AM
                                        • nrj1982
                                          Lenovo Ideapad3 NM-C821 faulty motherboard
                                          by nrj1982
                                          Hello all,
                                          I have a Lenovo Ideapad3 laptop, that has recently stopped working. When pressing the power button, the led is going on, but nothing else is happening.
                                          I have checked the 3.3V, 5V and 20V - all of them seem present (checked with multimeter and oscilloscope in order to verify that they are stable).
                                          I have checked the voltages around PU1901 - 0.9V, 1.8V, 5V, 2.5v, 0.6V and 1.2V - all of them are present.
                                          Now going further in the debug, I found that the CPU voltages produced by RT3662AC (PU5901) PWM driver are missing. I can see that the 20V...
                                          10-04-2025, 10:08 AM
