so i wake up this morning to turn on the tv and i get this surprise. When i turn on the tv the red led light blinks 1 time and the screen flashes once( grey looking) and then immediately goes black. I also hear a clicking noise in the process. The red led stays on constantly ( i assume that means no power). I have read alot about other problems where the led will blink 5 times or so but this is not the case with mine. I took the back panel off and had a look at the boards. I didnt see any indication of bad capacitors but i notice that the green led on the Logic board blinks continuously. Should i try to replace the board with the power supply first? Any ideas at all?
Samsung #PN51D450A2DXZA N411 Black screen, no power?
Re: Samsung #PN51D450A2DXZA N411 Black screen, no power?
Can you try this test on your control board? Since it's blinking continuously it might confirm a main board fault.
https://www.badcaps.net/forum/showpo...61&postcount=2Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
https://www.badcaps.net/forum/showpo...61&postcount=2Comment
When you do the test, if the main board is faulty, the TV will power on and a sequence of display test patterns will appear on the screen.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
ok, i'm doing the test now, what is happening is the screen is showing different colors (one at a time) and other tests( like a red screen with it fading to black). The green LED is blinking continusly on the Logic board. How long am i to let this happen? will it stop on its on? what now?Comment
This confirms the main A/V board is bad, unplug the TV for now and order a new board or get old one repaired.
Main A/V has HDMI ports, etc. on it.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Tom66, you are the man!!! Thanks a bunch! I'll just order a new board. I'll google a retailer to buy from unless you can suggest a site? Anyway, to replace the main board, is it just a matter of unscrewing the old one, disconnecting and reconnecting the new one and turning on the tv?Comment
ShopJimmy is a good supplier.
Order by the LJ9x-######Z part number, not LJ4x-######Z part number.
It is a good idea to match the suffix [A-Z] but that is not always possible.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
http://www.shopjimmy.com/catalogsear...450A2DXZA+N411
then i looked for the main board. http://www.shopjimmy.com/samsung-bn9...d450a2dxza.htm
I assume this is correct?Comment
Ah, looks like your set uses BN part numbers.
So check that the sticker is marked BN96-19471A matches what is printed on your board. If so that should work fine.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Great to hear, thanks for the repair feedback, enjoy your TV.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
so i wake up this morning to turn on the tv and i get this surprise. When i turn on the tv the red led light blinks 1 time and the screen flashes once( grey looking) and then immediately goes black. I also hear a clicking noise in the process. The red led stays on constantly ( i assume that means no power). I have read alot about other problems where the led will blink 5 times or so but this is not the case with mine. I took the back panel off and had a look at the boards. I didnt see any indication of bad capacitors but i notice that the green led on the Logic board blinks continuously. Should i try to replace the board with the power supply first? Any ideas at all?Comment
Hello, I congratulate the order and delivery service, I would like help because I install the power module you sent me and I have the same problem relay that clicks all the time. I did the test on the jumper pin 3-4 control board and disconnect the LVDS cable. result tv on relay click always but it becomes white in full a split second and disappears, it is done a repetition. What do you think? Thank you for your help.Comment
I also had corrosion/oxidation on the... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by totofHello,
I have my TV model UE50KU6070 which I am trying to repair.
BN41-02528A / BN94-10800C motherboard.
If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
After one minute the consumption drops to 0W and the TV can turn on with the remote control but... -
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappearedI bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
- Loading...
