Needs SPI dump for 17MB97
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Hello everyone, I have a constantly blinking Inexive LED TV.
    Display is: VES390UNVA-2D-N01
    Mainboard: 17MB97
    SPI IC: 25L1606E
    Thanks in advance!
  • yokoono
    • Apr 2010
    • 488
    For USB it is not good?​
    • unimatrix93
      • Oct 2021
      • 347
      • Magyarország
      I will try it tomorrow and report back!
      thank you!
      • Diah
        • Feb 2013
        • 6397
        yokoono ... i need only Profile of this MB 97 with working youtube and other content from vestel or any other,, i have one from telefunken need to change the profile
        • yokoono
          • Apr 2010
          • 488
          Update for youtube. Install with MENU 1505.​
          • unimatrix93
            • Oct 2021
            • 347
            • Magyarország
            I just format the usb drive to fat, place the files on it and put it in the TV USB port and turn the TV on, right?
            • yokoono
              • Apr 2010
              • 488
              1. Format the stick with FAT 32
              2. Unzip and put the files on the stick.
              3. PRESS AND HOLD the OK button on the remote control
              4. Plug the TV into 220v.
              5. The stby LED on the TV flashes slowly and then quickly. When it flashes quickly RELEASE the OK button.
              6. Wait for it to finish. It may take up to 5 minutes.
              • unimatrix93
                • Oct 2021
                • 347
                • Magyarország
                I did everything as you said, released the OK when it started flashing quickly and It's been blinking slowly for 10 minutes since then. Should I unplug it and restart?
                • yokoono
                  • Apr 2010
                  • 488
                  Theoretically the TV should start by itself with the first installation. If it doesn't, the software on the stick cannot be installed. The SPI memory must be rewritten with the programmer or the NAND memory. I don't have any other software.
                  Try another stick with a smaller capacity (max. 16Gb).​
                  • unimatrix93
                    • Oct 2021
                    • 347
                    • Magyarország
                    I used a 8GB USB drive.
                    I have a CH341 programmer and I found this dump on telegram.
                    It's for the same board and almost the same Display.
                    I try to flash this to the ISP chip. I will report back, wish me luck.
                    • unimatrix93
                      • Oct 2021
                      • 347
                      • Magyarország
                      Yeah I flashed the bin on the SPI and no luck, still blinking.
                      Anything else I could try?
                      • yokoono
                        • Apr 2010
                        • 488
                        Rewritten NAND memory or another motherboard. It could also be a hardware problem.
                        Nand memory cannot be rewritten with CH341A.​
                        • unimatrix93
                          • Oct 2021
                          • 347
                          • Magyarország
                          Rewritten NAND memory or another motherboard. It could also be a hardware problem.​
                          I don't have programmer for NAND memory sadly only ch341.
                          I started diagnosing the TV PSU.
                          What is weird that I have 30V on the backlight, but the backlight itself does not turn on.
                          • Diah
                            • Feb 2013
                            • 6397
                            thanks, its worked
                            • Diah
                              • Feb 2013
                              • 6397
                              Dear yokoono
                              Youtube working... but my friend lost the wifi.so only with LAN ,. yesterday i was at his home and even at service menu the wifi NON. editing swprofile didnt help..
                              do you have another firmware for Telefunken or any other for 17mb97 with panel VES315W NDB-2D-NO2 ?
                              THX
                              • yokoono
                                • Apr 2010
                                • 488
                                Dear yokoono
                                THX
                                Save the profile from the TV.
                                1. Format a stick with FAT32
                                2. Create a folder called downloadprofile.mb97 on the stick
                                3. Turn on the TV and type MENU 4725
                                4. Go to USB Options and type OK on the remote control
                                5. After 10 seconds you can remove the USB stick and you will have some files on the stick.
                                6. You post them here.
                                There are 17MB97 motherboards that DO NOT HAVE WIFI.
                                • Diah
                                  • Feb 2013
                                  • 6397
                                  swprofile i did modified it .
                                  he does have wifi because he used it before.. but now i am thinking when he open the cover could forget to plug the wifi in place....as i remember this TV the wifi module installed on the back cover LOL.. need to check this when i visit him next time
                                  • unimatrix93
                                    • Oct 2021
                                    • 347
                                    • Magyarország
                                    Is it possible to extract the SPI's content from this? To directly flash it to the 25L1606E?
                                    • yokoono
                                      • Apr 2010
                                      • 488
                                      NO.
                                      • unimatrix93
                                        • Oct 2021
                                        • 347
                                        • Magyarország
                                        NO.
                                        Damn.
                                        I bought an another main which was advertised for 39 inch displays. However the 8 character on the sticker is different. Mine is 23340018, the new is 23312214. The new board doesn’t even blink, no stand by led at all.
                                        Can I do anything with this board? Or should I try to send it back to the seller?
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • zvvvpnrsa
                                          ok.ODL 55651U-TIB I am looking for firmware via USB or SPI dump 25L1606E
                                          by zvvvpnrsa
                                          Hello, I am looking for firmware via USB or SPI dump 25L1606E
                                          ok.ODL 55651U-TIB
                                          Chassis (Main Board): 17mb130s 23516802
                                          Panel: VES550QNDL-2D-N12
                                          12-25-2022, 07:48 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Mephysis
                                          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                          by Mephysis
                                          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                          03-27-2025, 02:34 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
