If you have a completely clean dump, then most likely there is poor contact in the socket with the chip, dirty pins on the chip from flux, the power supply on the programmer is set to 3.3v, using a jumper, the chip is inserted correctly, not turned 180 degrees?
Samsung ue55tu7170u not turn on and no standby led main bn9650990e
Attached FilesComment
For your question I checked the board and I find two ic memory, ic501_ut that is q80c-104gip that should be a en25q80c-104gip but i didn't find a lot on internet. And in position ic503 that is a 25qb-104 gip that I find easy on internet. Are they what are you looking for? I give you the photoComment
The correct one is the Q40B (not 25q as you said, but is 25Q40 entirely) most probably, if you can enlarge the view on photo (please cellular in landcape not portrait), i can see testpoints definition, or better, if you can confirm the TP that belongs to that chip is named "MPU_debug_TX" you're 100% sure it is the standby mem. and you can flash it, you can use even from different size of screen but same series..Comment
ok first thing i try to desolder it from the main and read, and see what i have, then hope someone here can help me.Comment
really if it s the problem we found the problem...then we just need to find a dump i hope Iotas can help me, he is like a god of dumps ahahah. honestly i never read an ic in my life....it s the second so i dont know for that i put the dump file here if someone can help me...and didnt work so we can try also other dump maybe we are lucky....hope someone can help me...Comment
I tried to extract it from official Samsung site update file, it's very difficult, i tried this site: specifying the following params (using my imagination) and giving the "..\T-KTSU2DEUC\image\upgrade.msd" file to it , my OLD computer runs out of memory and started to give numbers.. if you want you can try yourself..
so i tried the site, i download the firmware update from samsung, i put the file upgrade.msd in that site but give me back after try to decrypt bad decryption....Comment
Iotas we need your magic......Comment
my skill is over the moment it s not a diode in short hahah so im far away, with your parameter i had a file but it s 1 gb...so i think i have to find the part i need, or i made a mess ahha but i really cant do nothing ahah it s over my knoladge. dont worry i dont do nothing i didnt sold back the eprom too ahah waiting an help from you ahahComment
are you saying that the web page i gave you made a file for you of 1Gb? That file can contain or not the mini flash data, but i cannot receive the file, it's too big, i wonder why my pc can't handle it, maybe limited virtual ram file.. i'll check
so i had an idea to look for with the comand find in the text edit software to find the first words of the dump i extract from the 25q40Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by JackchingI know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
by Doodle43My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I... -
by marcinqHello,
I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....4 Photos - Loading...
