WESTINGHOUSE EW24T7EW - no backlight
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    i have a WESTINGHOUSE EW24T7EW with inverter board MP113S-39.
    looks almost exactly like this: http://www.shopjimmy.com/media/catal...13s-39-top.jpg
    i did a thorough look through to see if any caps were even slightly bulged or any melt marks anywhere, but found nothing out of the ordinary.
    i can faintly see the westinghouse logo when i turn the tv on so i checked the voltage at the backlight plug con5 and got 6 volts receeding to 0.
    so i applied 18v to the backlight and turned the tv on, the logo appeared (not full bright, but enough to see clearly)
    is there anything i can do to revive the board? or just find one for like 20-30$
    thanks, me
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    Re: WESTINGHOUSE EW24T7EW - no backlight
    forgot to mention that the tv had this problem, but i put the tv away for a while, decided to try it again before digging into it and it suddenly decided to start working and did work for months.
    • bammbammfran
      • Apr 2014
      • 476
      why did you run 18 volts to the inverter when it looks like it is only supposed to use 12 ?
      Where do con 4 and con 5 lead to and do they have voltage and is that voltage steady?
      • jasonbay13
        • Jul 2014
        • 185
        • usa
        i started at 3 volts and kept going up until i saw something at 18. so i would assume its 24volt.
        and i dont know where con4 and con5 lead to. i could get a clear picture of both front and back if it would help. but it looks like they are in series and one side goes to ground? and the other side goes through a bunch of little resistors?
        i'll check for voltage further down the line when i get to it.
        • bammbammfran
          • Apr 2014
          • 476
          Well, I found a bottom picture of the board and it says 12volts on two of the pins at con2
          then it also looks like this may feed a voltage regulator at Q11 which might be 5 volts to those two connectors ??? If those two connectors do not lead anywhere then that voltage may just be a feedback current to the one 8 pin IC at IC2
          check voltages with the board all by itself and then again with it connected to the main board
          • jasonbay13
            • Jul 2014
            • 185
            • usa
            ok, i did some testing. and i shorted +12 to bk/on with my black lead and put the red lead to various places. (first at the terminals on connector 4 and 5). at con5 i get -11.8v and at con4 i get 48v quickly dropping to 0, but goes back to 48 everytime i re-short +12 and bk/on.
            i get 11.8v everywhere i checked except the section with con4, and down to the resistor? with 3903 (R27) on it, but the other side of the resistor has 11.8?
            i can draw up an image if you want me to of where i checked voltages/where you want me to check voltages.
            • bammbammfran
              • Apr 2014
              • 476
              Sorry, but, I can't play by your rules
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • JaquesPratt
                Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                by JaquesPratt
                I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                07-16-2024, 01:04 AM
              • vf fa
                EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                by vf fa
                Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                01-31-2024, 01:40 PM
              • DanPoka
                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                by DanPoka
                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
