Samsung qe55qn90aat
  • porfyriadhs
    • Oct 2023
    • 70
    • Greece
    Samsung qe55qn90aat
    Hello I have a problem with a Samsung qe55q90naat. There is no picture. Tried to tape ribbon cable pins but nothing happens. It is a New model and need help please
  • porfyriadhs
    • Oct 2023
    • 70
    • Greece
    • nomoresonys
      • 12210
      • U.S.
      Is the second picture with the half screen with everything connected?
      • nomoresonys
        • 12210
        • U.S.
        Here's some simple things to try, just in case, but might be something harder: https://www.youtube.com/watch?v=gysJRUcAmTM
        • nomoresonys
          • 12210
          • U.S.
          If anyone has special knowledge of this model they can probably help too, here's some tests to try: with tv unplugged from power unhook cable from powerboard to mainboard at powerboard, plug power cord into powerboard, see if backlights come on and stay on. If it passes that test, plug that cable back in, unhook cable from mainboard to driverboard (which is at the top in the picture) at the mainboard, turn tv on, give it a minute, see if you have optical port lit red and listen for a tone/chime from the speakers indicating tv is turning on. Each time a cable is unhooked or hooked back up, make SURE tv is unplugged from power. Do tests report back.
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • triplefour
            LG 75UN8570AUD panel issue fixed with tape.
            by triplefour
            I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
            add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
            07-17-2023, 10:22 PM
            09-07-2024, 05:50 AM
          • Dobsuk
            Samsung UE50TU8000K no picture or lanes on it
            by Dobsuk
            Hi guys, i am dealing with one Samsung 50TU8000K which was without picture - just was resetting itself constantly. Saw some videos and read some post about simmilar issue and the advise was to try to tape cut off method and started to put tape on some of the pins on this ribbon cable:
            And then i had picture but with lanes. Tried different pins and combination but could not managed to make it work without any lanes so far. Will keep playing with it though.
            The weird thing is that i tried it again without any tape on the pins and now i have picture with just few lanes...
            04-25-2023, 07:34 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
