  • Chrissygizmo
    • Mar 2021
    • 108
    • United Kingdom
    I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same program go light & dark. I will upload photos of this to try explaining better. Gogglebox was coming to an end & I started recording it on my phone, the picture is watchable until the screen changes to the advert . I’ve also noticed that when the full screen is light & watchable, the right side is still funny , you will notice that the people on the right of the screen look sun tanned (they aren’t lol) .
    Thank you in advance for your time 😊
  • Chrissygizmo
    • Mar 2021
    • 108
    • United Kingdom
    The last 2 pictures are the wrong way around, they are screenshots of the recording I mentioned, it is gogglebox sponsored by 3 then a change of image to the channel 4 & a map of GB with half the screen darker
    • EazyBone
      • Jun 2023
      • 1342
      • United states
      This is exactly what you thought. The LEDs are bad. Sometimes LEDs will turn on for a few minutes and then go out then on and off etc, many phenomenon occur. You can test them and they are fine out back together and bad. Take apart and test bad. This is clearly a light issue though.
      ​​​​​​JJust change em out and I'm sure you'll be fine.
      You can check connectors etc to see if loose but I've never been lucky like that
      • Chrissygizmo
        • Mar 2021
        • 108
        • United Kingdom
        I’ve had the screen off again and left it off for over an hour, the backlights stayed on with no issues, I’ve read on here that it could be something to do with the side cofs , but it says that this is a last resort as it’s not reversible , if the screen has cofs on both sides you have to remove all the cofs on the dark side of the screen , i will try this as a last resort as the tv is still watchable
          • 12206
          • U.S.
          This doesn't seem like a side cof issue, usually bad side cof looks like horizontal lines that don't go all the way across or a green kind of a mess on one side. Usually you can tell a bad side cof by inspecting the cof, a bad chip will look burnt, be misshaped, have a hole in it or maybe be much hotter than the others. Go ahead and inspect them. I would more suspect the tcon with these symptoms.
            • 12206
            • U.S.
            Can clean the flat cables going from tcon to panel with a pencil eraser, sometimes it's dirty and causes problems. Also make sure cable from mainboard to tcon is clean and fits securely.
            • Chrissygizmo
              • Mar 2021
              • 108
              • United Kingdom
              Thank you for your input, I already tried cleaning the lvds cables with a pencil rubber I should of mentioned that in my post but I'm glad you cleared up the side ribbon part because I was almost ready to have a go at that , I will try the replacing the t-con board next , also I’m not sure if this would help to clarify the issue but I tried removing one t-con cable at a time & there was no picture or half picture when either side was removed, only a blank screen
              • Chrissygizmo
                • Mar 2021
                • 108
                • United Kingdom
ID:	3570209 Click image for larger version
ID:	3570211 Click image for larger version
ID:	3570210 Click image for larger version
ID:	3570213 Click image for larger version
                It did originally have vertical lines, I used the sticky tape method to get past that , I've just removed the sticky tape & I will upload some pictures of it,
                  • 12206
                  • U.S.
                  Some tcon testing there, interesting how many ways a bad tcon can display: https://www.youtube.com/watch?v=_hOMC2qn6jY
                  • EazyBone
                    • Jun 2023
                    • 1342
                    • United states
                    Well that data would of been nice
                      • 12206
                      • U.S.
                      Yet here's another that has similar display as you show in the pictures that was bad backlight led/s. He did ok I guess but if replacing leds DO NOT use his same method, he was very lucky not to break the screen/panel: https://www.youtube.com/watch?v=raicZqT-qVo
                        • 12206
                        • U.S.
                        All these things just show that you should never jump to conclusions, start simple eliminate thru testing and go on.
                        • Chrissygizmo
                          • Mar 2021
                          • 108
                          • United Kingdom
                          I’ve removed the side cofs & it’s working spot on Click image for larger version
                            • 12206
                            • U.S.
                            That's good, as you can see many issues mimic other issues, so it can be tough to tell exactly where the problem is just by observing the display. We always use extreme caution when removing side cofs because it's not reversible, this time it was the issue. Did you inspect those cofs and find a defect?
                            • Chrissygizmo
                              • Mar 2021
                              • 108
                              • United Kingdom
                              I would love to say yes, I found a bad ribbon/cof but the truth of the matter is I'm really impatient, I was going to order a new tcon board for it but my impatience got the better of me & away I went pulling the cofs off , I just thought “FK IT I GOT IT FOR NOTHING” I know that's not the way to think about it but that's what happened, I did have an inkling about the top cof on the right side (bad side) I will insert a picture, I thought/hoped/wanted it to be the damaged one. I've put it next to another one of the cofs to compare. I’ve arrowed where I thought looked bad , just around the top edge, it looked slightly burnt compared to the rest, (VERY SLIGHTLY THOUGH) …
                              . Click image for larger version  Name:	IMG_1194.jpg Views:	0 Size:	253.9 KB ID:	3572081
                              • Chrissygizmo
                                • Mar 2021
                                • 108
                                • United Kingdom
                                this is what I was expecting to happen but I got away with it “THIS TIME” I need to be more PATIENT in the future because I’ve been I in the position of putting TV’s back together after repairing them & I’ve managed to crack a couple of screens, torn part of a cof off & more stupid impatient accidents that I would prefer to forget DOHH
                                  • 12206
                                  • U.S.
                                  Yes, I do think that cof is burnt, you did very well tracking down the problem. So many just throw them out and overflow the landfills. I have a 70 sharp that got this operation over 2 years ago, going strong, I don't notice any distortion on either side but it may be very slight.
                                  • Chrissygizmo
                                    • Mar 2021
                                    • 108
                                    • United Kingdom
                                    Thank you for your input, I found it very helpful as usual, I am going to post a problem concerning lines on a Sony KD-55XG9505 , hopefully you might be able to help me again especially with your username l
                                    • Tom C
                                      Samsung QN55Q70AAFXZA Half Screen Dim
                                      by Tom C
                                      I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                                      Any suggestions would be appreciated.
                                      thanks.
                                      09-19-2024, 07:22 PM
                                    • JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                      by JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                      Please help. Thanks in advance!
                                      08-12-2025, 11:45 AM
                                    • Raulnn
                                      TD Systems K50DLG12US half black and half white screen
                                      by Raulnn
                                      good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                      By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                      01-20-2024, 04:49 PM
                                    • ItalianSat
                                      LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
                                      by ItalianSat
                                      Hello Everybody,
                                      I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
                                      Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
                                      Moreover, I detached the T-CON board for a new round of investigation. I personally...
                                      06-28-2022, 06:02 AM
                                    • arbitarytwist
                                      Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                      by arbitarytwist
                                      Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                      Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                      03-01-2025, 01:16 PM
