sony MCM2250
  • dadopo
    • Jan 2025
    • 7
    • Italia
    sony MCM2250
    Hi everyone, I wanted to ask for an opinion, I have 2 identical monitors, only the firmware and serial numbers change, 1 has a faulty card, the other I should put the firmware and serial number of the faulty card in the other working one, in the photo there are 2 eproms, the one on the bottom left of the processor and the one on the top right, I changed them, but nothing has changed, do you think I can do other tests?
    Thanks to everyone
  • lotas
    • Jan 2016
    • 4785
    • Russia
    What you changed is spi flash (25 series), look also on the eeprom board or take a high-quality photo of the board on both sides so that you can see all the chips.
    • dadopo
      • Jan 2025
      • 7
      • Italia
      I hope it's clear enough, I swapped the two Winbonds but nothing, I have doubts about the MXIC chip
      • lotas
        • Jan 2016
        • 4785
        • Russia
        That’s it, there’s nothing visible, I asked you to take a high-quality photo in high resolution.
        • dadopo
          • Jan 2025
          • 7
          • Italia
          Sorry, this is
          • lotas
            • Jan 2016
            • 4785
            • Russia
            It's hard to see in the first photo, but in the second it's not that, it's a temperature sensor.
            • dkneyle
              Sony KDL-46HX850 Can't upgrade/update firmware
              by dkneyle
              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
              09-25-2024, 10:44 PM
            • joby91
              SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
              by joby91
              I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
              I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
              I found one chat about firmware on ************** forum but i cannot read the comments.
              https://**************/forum/108-114100-1#880537
              09-04-2024, 01:34 PM
            • jason123
              Sony Firmware for XBR-70X850B
              by jason123
              Hello
              Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
              I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
              Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
              Much appreciated.
              05-17-2022, 12:42 PM
            • AlexWhat
              SONY KDL-65w850c need latest firmware 6.827
              by AlexWhat
              In 2022 SONY did "Termination of TV Software Update" for this model.
              I did find older firmware but it can't be installed over newer one (rolled back)
              Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
              12-15-2024, 11:32 PM
            • cheeky2
              Help with Sony firmware KDL-40W5500 v1.752EA
              by cheeky2
              Unfortunately Sony Have taken all there old TV firmwares down from there website last year. So it isn't available to download. Does someone have the firmware available please? It is used for a whole range of the KDL range of TV's including the following models :
              KDL-22E5300, KDL-22E5310, KDL-32E5500, KDL-32E5510, KDL-32E5520, KDL-32V5500, KDL-32V5610, KDL-32W5500, KDL-32W5710, KDL-32W5720, KDL-32W5730, KDL-32W5740, KDL-37V5500, KDL-37V5610, KDL-37W5500, KDL-37W5710, KDL-37W5720, KDL-37W5730, KDL-37W5740, KDL-40E5500, KDL-40E5510, KDL-40E5520, KDL-40V5500, KDL-40V5610, KDL-40W5500, KDL-40W5710,...
              01-28-2023, 06:13 PM
