Samsung LN-T3242H works fine for a day, then wont turn on. intermittent.
    Re: Samsung LN-T3242H works fine for a day, then wont turn on. intermittent.
    There are printing by the connector telling you what the pins are. Look at the picture in post 2, it is out of focus so we cannot tell what the labels are.
    • triplefour
      • May 2014
      • 1747
      spokm yea thats what i did. those little wires are going into the LCD i think. budm heres the label on the psu connector. there is no label on the connector on the inverter board.
      Don't fear the repair...
      • triplefour
        • May 2014
        • 1747
        why is there that second connector that is empty??
          Man, you are not helping.
          What are those printing then? I gave up.
          • triplefour
            • May 2014
            • 1747
            sorry i didnt see those earlier and didnt understand which labels you wanted.
            please dont give up on me!
            this is a good picture of that label.
              Take the DC voltage reading on pin 12 (ON/OFF), 13 (I-PWM), 14 (E-PWM).
              • triplefour
                • May 2014
                • 1747
                12: 5.3
                13: 3.4
                14: 0.5
                11 which says error is 0
                  OK, the inverter is getting the correct signal and voltages. Inverter transformer resistance testing will be required next. Need the numbers as printed on the top of the transformers.
                    BTW, the power supply board has two connectors so it be used with more than one model of the inverter board, since same model TV can have difference make and model of LCD panel assembly. You can see that all the pinouts of the two connectors are not the same.
                    • triplefour
                      • May 2014
                      • 1747
                      that makes sense. i noticed the pinouts were different too thats why i didnt want to try plugging it in there
                      • triplefour
                        • May 2014
                        • 1747
                        ok the transformers are labeled 4018L 0742T5 SD-2
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #32
                          this may help you to run tests
                          http://lcdparts.net/TransformerDetai...ProductID=3497
                          • triplefour
                            • May 2014
                            • 1747
                            can i test this in circuit?
                            • triplefour
                              • May 2014
                              • 1747
                              but if one transformer costs 20$ i might as well buy a new inverter board if thats what it is...
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #35
                                yes test in circuit these may not be at fault i think budm is just ruling them out at the minute and you can buy these a lot cheaper of ebay etc.
                                • triplefour
                                  • May 2014
                                  • 1747
                                  all the transformers check out ok according to those specs
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    yes i see the value in ruling them out....so what else could it be though?
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      i noticed while testing the transformers, that some of them would test good using the solder joints but on some of them i had to go closer to the legs to get a proper reading. could this be a sign of weak solder joints causing the problem?
                                        One thing I would like to try is to disconnect the #14 pin wire only from the inverter connector to see what happen.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #40
                                          did you see this post? same 4 blinks same inverters used
                                          https://www.badcaps.net/forum/showthread.php?t=14105
                                            09-07-2024, 05:50 AM
                                          • C152Heavy
                                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                            • Have read ALL applicable threads
                                            • C1818 and CP820 replaced as low hanging fruit
                                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
