JVC LT-58MAB887
  • d2fx
    • May 2015
    • 24
    • french west indies
    JVC LT-58MAB887
    I need the firmware update please
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • rumpumpel1
    ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
    by rumpumpel1
    Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
    10-24-2024, 08:59 AM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
  • pp74
    Marantz NR1508 USB firmware update image
    by pp74
    Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
    Regards
    05-10-2025, 11:55 PM
  • Faluky
    firmware for Marantz SR5008 stuck in update loop
    by Faluky
    After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
    Best regards.
    Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
    01-17-2023, 04:33 AM
