Samsung LE32d400 double image
  • beogeek
    • Apr 2018
    • 100
    • Serbia
    Re: Samsung LE32d400 double image
    Originally posted by branislav18
    Here are the pictures of t-con and that braon one flat cable
    I know I'm late to the party, but here's the issue for anyone still potentially having this problem.
    The problem 99% of the time is the TVS diode array, it's the IC labeled 7512N.
    I've circled it in one of your photos. I've also uploaded the datasheet for it. You can find the replacement on Aliexpress/Mouser.
    Replacing it fixes this issue.
    • Cornito
      Samsung UE55RU8000 reboot and then double image after heating up
      by Cornito
      Hello team,
      I'm back with another tv and another problem.
      I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
      First, reboot issue, I use tape Method to find out the right side that cases the issue.
      Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
      Then double image reduce in height and move to the top.
      The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
      When I...
      03-31-2024, 01:37 PM
      09-07-2024, 05:50 AM
    • howardc64
      TCL 49S405 double image
      by howardc64
      LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
      This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
      06-23-2025, 03:20 PM
    • shlomim412
      samsung ua55es6800 - no image
      by shlomim412
      hi
      having problem with samsung ua55es6800
      tv had backlight on, sound working - responds to the remote control but no image.
      check tcon board - had 12v in but no other voltages present.
      when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
      when leaving only left side connected - again no voltages and no image.
      put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
      kept trying to block less pins on the left ribbon cable...
      05-15-2024, 05:00 AM
      09-06-2024, 11:40 PM
