Line filter\choke - gluing broken ferrite core?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5008
    • New Zealand
    I've got a Dell power supply I'm recapping. Currently it's running with some substitute capacitors from another supply and I was about to do a proper replacement with good parts when I noticed that a piece of the ferrite core on the line filter has been broken off and was sitting in the bottom of the PSU case.
    I'm wondering if I can just glue this back together? I know transformer cores are normally in two halves and are glued at the factory but how much difference will this make when the ferrite has broken?
    Is there even any point? As far as I know the only point of the choke is to filter out the high frequency switching noise and prevent it from getting on the power line, so it shouldn't affect PSU operation - maybe just operation of anything else I have!
    I was going to replace the filter with one from a dead PSU but being Dell they have used a low-profile one and the pin spacing is all wrong.
    -David VanHorn
  • redwire
    • Dec 2010
    • 3912
    Re: Line filter\choke - gluing broken ferrite core?
    Is the core just chipped or is it broken in two?
    Gluing two halves together always results in an tiny air-gap, so the inductance ends up lower. This should not make a huge difference, just more line noise.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5008
      • New Zealand
      Neither, a piece has broken out of the corner. Stuffed if I know how too, it's buried in there pretty well.
      -David VanHorn
      • redwire
        • Dec 2010
        • 3912
        Oh it's an E-core. I would epoxy it together in two steps.
        One, put in the busted piece with glue on each cracked end, snug as possible.
        Two, after that dries, a big blob to keep the piece from ever falling out.
        Ferrite is like glass and breaks easily. It's also conductive and shorts stuff out if it lands on the PCB.
        Or just be lazy and leave it alone. The remaining two E-core legs means it will still work, although not as good.
        • Trick Fix
          • Apr 2014
          • 13
          • Serbia
          Good day to all,
          This is my first answer.
          I think the broken core can stick with and glue in a thin layer.
          I believe that it will work OK,
          it had already tried and works well.
          It is important that the adhesive layer as thin as possible.
          greeting
          • Agent24
            I see dead caps
            • Oct 2007
            • 5008
            • New Zealand
            I think I will put it back together, just for 'completeness' and to hopefully further minimise noise. Easier than trying to replace the whole thing anyway.
            Any particular epoxy\glue I should use?
            -David VanHorn
            • redwire
              • Dec 2010
              • 3912
              I use 5 minute (two-part) epoxy. Crazy glue cyanoacrylate might work, but I would put something (blob) on the core to stop the part from ever getting loose in the psu.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5008
                • New Zealand
                I usually use Araldite but I have run out at the moment. Thinking of getting some JB Weld for something else, would that do - or is it overkill 9000?
                -David VanHorn
                • Trick Fix
                  • Apr 2014
                  • 13
                  • Serbia
                  I know the Araldite,-good, but it's a little thick for this application,
                  I still think you should have to use some super glue that is very liquid,
                  and with it that part of the paste in which it separated.
                  I said earlier that it is important to glue it to the thin layer to the input Filter performance remained the same.
                  >I apologize if something bad interpreter<
                  Not in bad faith,
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    I'd go go for cyanoacrylate perhaps with some activator to help with the porous surface.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Meh, all those fancy glues ... just use hot glue and be done with it.
                      The way I'd do it is first place the part where in needs to go, then apply a hefty amount of hot glue everywhere. Should definitely keep it from going anywhere.
                      Don't be like Bestec, though, and jizz glue on absolutely everything.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5008
                        • New Zealand
                        I would agree but I think Trick Fix has a valid point - the glue layer should be as thin as possible to give maximum peformance. If you look at ferrite transformers and chokes, they have very thin glue layers between the two core halves as standard from the factory.
                        I'll give it a try when I get around to getting some new epoxy. At the moment the thing seems to work so it's not a high priority.
                        -David VanHorn
                        • Trick Fix
                          • Apr 2014
                          • 13
                          • Serbia
                          http://edn.com/electronics-blogs/liv...Ferrite-Cores-
                          http://jimlaurwilliams.org/wordpress/?p=3337
                          • “Eabdel”
                            Broken capacitor and the PCIE line on RTX 3090 FE
                            by “Eabdel”
                            I have a RTX 3090 Founders Edition and it's detected as PCIE X4 instead of X16
                            I took a look to the PCB and found that a capacitor, wich is linked to and the PCIE fingers lines, is broken. I count and it's on the 32 position (exactely the end of the PCIEX4)
                            Anyone knows this capacitor specification? I see some other models boardview and seems to be linked to the ground
                            Can I just solder the trace between them with no capacitor or it's risky?
                            Thanks...
                            04-10-2024, 08:00 AM
                          • Dannyx
                            Line filter question
                            by Dannyx
                            Good day folks. A while back, I started building a bench power supply (long story - see it here ). I noticed something about the pre-built line filter I wanted to use and it got me thinking whether it's a good idea to use it or not, at least in my particular case.
                            If you zoom in and look at the schematic on the label, the potential problem I see is the earth terminal connected to L and N via the 2 Y caps. I've seen this setup in virtually all of these and even some SMPS board may have this arrangement (though I'm not sure about this), so it's probably safe overall and makes perfect...
                            05-08-2022, 04:31 AM
                          • cubytus
                            Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                            by cubytus
                            Hi to all,
                            I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                            I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                            Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                            01-10-2024, 01:26 AM
                          • chth96
                            Is it possible bridging tiny broken trace
                            by chth96
                            When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                            cutting tiny trace.
                            This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                            Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                            But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                            12-03-2022, 11:32 PM
                          • otaku_nut
                            Vizio E701i-A3 fixed but now has red vertical line
                            by otaku_nut
                            Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                            08-19-2025, 06:11 PM
