LG 50PG20 Plasma - Will Not Turn On
  • WillyGoat
    • Jun 2014
    • 6
    Hello all!
    Almost two weeks ago, I came into possession of an LG 50PG20 plasma TV that will not turn on at all. No red standby light or anything. The original owners tried getting it repaired once already and the repairman told them it was a problem with one of the fuses on the power supply. He tried fixing it by replacing the bad fuse but the original owners of the TV said it didn't last very long. However, I don't think the repairman did a very good job, as I'll get to in a moment.
    I took the back off the TV and none of the caps on the power supply or other boards appeared to be bulging. However, in my research I've read that capacitors should be flush with the board but on this TV's power supply board, a few of the caps have a bit of space between their bottoms and the board. Nothing appears to be leaking out of those caps though, so I don't think they are damaged but I'm not 100% positive.
    Upon further inspection of the power supply, I noticed that one of the thermistors (location TH101) is damaged and a good part of it is missing. I also noticed that one of the fuses (in location F801) is blown. From what I've read, it seems that usually when a thermistor or fuse goes out, it's because of some other problem with the board. Now, could that problem be that when the original repairman replaced this fuse, he didn't clip the leads and they are bent towards each other? I'm guessing that's bad and the reason the fuse is blown but could that also be the cause of the broken thermistor? Also, I'm assuming these two issues could be why I don't get even a standby light, correct?
    At this point, I'm not quite sure how to proceed. I know the thermistor and fuse need replacing and I think the ones I've linked to are the correct parts needed to replace them (please let me know if I'm mistaken) but I'd rather not replace them just for them to go out again because I didn't fix the underlying problem. So any suggestions on how to proceed from here would be most welcome.
    Please let me know if any additional images are required. I just have a cheap Canon point-and-shoot but I'll try my best to get good pictures.
    Thanks in advance for all your help!
  • noobohpjay
    • Jun 2018
    Re: LG 50PG20 Plasma - Will Not Turn On
    New user here, looking for an answer as well! Standby light went off too. TV was working several hours ago.
    • R_J
      • 9588
      Shopjimmy has a repair kit http://www.shopjimmy.com/lg-eay41360...-50pg20-ua.htm I would start by checking these components
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        From the pics, it doesn't seem that any of the caps are bulging (that does not mean they are good) and as RJ suggests look at those parts in the repair kit as a start. However, with some novice going in there first I am not sure what damage he could have created. An option, left to your discretion, too is to replace the PSU all together.
        • Ted29946
          LG 50PG20-ua Plasma TV repair help
          by Ted29946
          I'm new to this so I hope I'm doing it right So....I picked up a LG 50PG20-ua Plasma TV (Someone's throwaway pickup) First power up no picture or sound
          Found power board to be bad and I repaired it. (Bad caps) Now all power volt readings are good. Still no picture or sound. I plugged in power cord, no click and the standby light on the on/off button comes on blue as soon as it is plugged in and does not turn off when button is push. I then pulled the main board off to look at it better and the initial inspection (front and back) I cannot see anything bad. Before I put the board back
          10-24-2024, 11:12 AM
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • socketa
          Corsair TX650W fuse, NTC thermistor, and (APFC? Power Transistor) fried
          by socketa
          I read through this thread, and just want to confirm what i should do.
          https://www.badcaps.net/forum/showth...hlight=24N60C3.
          This person's fault was exactly the same as mine, even down to the power strip and with the muffled popping sound.
          I suspect that my problem started with an old power strip, of which a computer and a 2000W heater were plugged into...
          I noticed melting and heat where the heater was plugged in, so i plugged the heater directly into a double wall socket, but still noticed the muffled pop sound when i turned on the computer, and...
          07-18-2021, 02:09 AM
        • nmbb
          Can not find Model/Value of Thermistor.
          by nmbb
          Machine: Autoclave.
          Brand/Model: SANYO MLS-3780
          Manual: (Sorry search option not working on this PDF)
          Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
          06-02-2022, 05:55 PM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
