TV Sharp LC-49CFE6242E - not working - 2
  • betmen
    • May 2019
    • 90
    • Croatia
    I wrote a topic earlier for this TV...https://www.badcaps.net/forum/troubl...2e-not-working
    I managed to fix the power supply but there are still some faults. The sound works a little and then doesn't work a little and the tv doesn't respond to the remote control at all (I've tried several remotes).
    I suspect the motherboard...is there anything that can be fixed or does it need to be replaced?​
  • lotas
    • Jan 2016
    • 4803
    • Russia
    Do you have a programmer that supports NAND Flash, if so, then read the dump of this NAND and post it here, I will check it and clear it of bit errors...
    • betmen
      • May 2019
      • 90
      • Croatia
      I don`t have NAND Flash programmer...
      • betmen
        by betmen
        I get one old TV, Sharp LC-49CFE6242E which is not working.
        When turning on the TV, the inscription SHARP is displayed on the screen and after a few seconds the TV turns off.
        So far I haven't found what voltages should be at the output of the power supply and I haven't made any measurements.
        If anyone has any ideas, please let me know.​
        Starts
        10-19-2024
        Ends
        11-19-2024
        10-20-2024, 08:44 AM
      • tranquility
        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
        by tranquility
        i want to repair an Onkyo TX-NR809 receiver.
        symptoms:
        on power on, display appears and i hear one click. enue functions is given.
        - no hdmi output
        - audio output not tested, but i think it is not there
        - usb sticks are not recognized
        if i read out the chips with display+standby button + tone+
        both dts show only ????
        chip is D830K013BZKB4
        things i have done:
        - reflow of the dts chip without taking off and reballing
        - changed the aluminium caps without the big one with 25v because i dont...
        08-25-2025, 01:04 AM
      • MarkC1970
        Nand dump needed for Sharp 32CHF5111K
        by MarkC1970
        Can anyone link me to a NAND dump for a Sharp 32CHF5111K. It is built using the TP.MS3463S.PB711 board, it has all 3 HDMI ports and no SPI chip.
        Thanks.
        02-22-2023, 11:13 AM
      • mattpd
        PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
        by mattpd
        PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
        No LM damage. UART gives a generic "APU not responding" error.
        Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
        I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
        So to those with experience, would you expect at least a little heat from the NAND during...
        09-02-2025, 09:42 AM
      • MMH3
        Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
        by MMH3
        i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
        Never ever i experienced problems with that.
        Now i have one 5050sff machine, where this jumper isnt working at all.
        I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
        The history of the machine is that i used it in my office...
        03-23-2025, 09:28 PM
