TV Sharp LC-49CFE6242E - not working - 2
  • betmen
    • May 2019
    • 90
    • Croatia
    I wrote a topic earlier for this TV...https://www.badcaps.net/forum/troubl...2e-not-working
    I managed to fix the power supply but there are still some faults. The sound works a little and then doesn't work a little and the tv doesn't respond to the remote control at all (I've tried several remotes).
    I suspect the motherboard...is there anything that can be fixed or does it need to be replaced?​
  • lotas
    • Jan 2016
    • 4880
    • Russia
    Do you have a programmer that supports NAND Flash, if so, then read the dump of this NAND and post it here, I will check it and clear it of bit errors...
    • betmen
      • May 2019
      • 90
      • Croatia
      I don`t have NAND Flash programmer...
      • betmen
        by betmen
        I get one old TV, Sharp LC-49CFE6242E which is not working.
        When turning on the TV, the inscription SHARP is displayed on the screen and after a few seconds the TV turns off.
        So far I haven't found what voltages should be at the output of the power supply and I haven't made any measurements.
        If anyone has any ideas, please let me know.​
        Starts
        10-19-2024
        Ends
        11-19-2024
        10-20-2024, 08:44 AM
      • tranquility
        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
        by tranquility
        i want to repair an Onkyo TX-NR809 receiver.
        symptoms:
        on power on, display appears and i hear one click. enue functions is given.
        - no hdmi output
        - audio output not tested, but i think it is not there
        - usb sticks are not recognized
        if i read out the chips with display+standby button + tone+
        both dts show only ????
        chip is D830K013BZKB4
        things i have done:
        - reflow of the dts chip without taking off and reballing
        - changed the aluminium caps without the big one with 25v because i dont...
        08-25-2025, 01:04 AM
      • TyMercer
        Can I flash a working BIOS from one computer to another of the same make, model, etc?
        by TyMercer
        Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
        11-13-2025, 09:39 PM
      • MarkC1970
        Nand dump needed for Sharp 32CHF5111K
        by MarkC1970
        Can anyone link me to a NAND dump for a Sharp 32CHF5111K. It is built using the TP.MS3463S.PB711 board, it has all 3 HDMI ports and no SPI chip.
        Thanks.
        02-22-2023, 11:13 AM
      • mattpd
        PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
        by mattpd
        PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
        No LM damage. UART gives a generic "APU not responding" error.
        Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
        I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
        So to those with experience, would you expect at least a little heat from the NAND during...
        09-02-2025, 09:42 AM
