Sony Aquos LC-42D40U The screen lights up white, then dissolves across
  • DeeMisetz
    • Jun 2014
    New to the community, first time posting.
    It is an older model, but, if i can save it at a fair price and with out too much headache, it'll serve as a spare TV in the garage. It belonged to my friends father. Not too much info was available how it ended up this way, "One day it just stopped working". Video included.
    https://drive.google.com/file/d/0Byl...it?usp=sharing
    Any insight would be great. If there are too many, "could be this..or that", I'll just leave it to the curb.
    Thank you in advance
    DeeMisetz
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Sony Aquos LC-42D40U The screen lights up white, then dissolves across
    I have a strong feeling ts the panel that has a short in it.
      It does looks like bad panel due to bad TFT drivers. I would try having the ribbon cables between the T-CON and the panel connected one at a time to see what will happen.
        One possibility is low supply voltage to T-con, I have seen this effect on some LCD monitors with bad capacitors causing the 12V or 5V line to drop out.
        • DeeMisetz
          • Jun 2014
          Thank to everyone for taking the time to help and offer some ideas on the matter. I will try my best to make good use of them.
          Thanks again,
          DeeMisetz
          • Audeze
            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
            by Audeze
            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
            Does...
            10-06-2024, 08:54 PM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • Watson306
            6 Red Blinking lights (left side darker) on Sony KD-49XE8396
            by Watson306
            I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
            I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
            I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
            Many Thanks in advance.
            11-01-2022, 05:33 AM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:27 AM
