LG 60PH6700 issues.
  • Loanrangie
    • Oct 2024
    • 6
    LG 60PH6700 issues.
    I picked up this 60" plasma a few months ago as a freebie with the proviso that it may not be working, it was close to home so took a gamble.
    When first switched on most of the time it will boot to the LG logo then freeze but occasionally i just get a blank screen with back lighting, sometimes it will boot up to a usable state and i am able to watch tv and use the smart features like youtube.
    I pulled the psu board out looking for dry joints or bulging caps but caps look fine and there are no obvious dry solder joints, i haven't removed any of the other boards since my knowledge is limited to replacing caps and modding game consoles( jtag/rgh/chips etc).
    Would be good if i can save this tv instead of going to the tip.
  • mamado mosa
    Slow boot dell latitude 5410 laptop issues
    by mamado mosa
    So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
    The problem is it takes more than a minute to boot ..
    The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
    Can someone suggest something to fix
    06-19-2025, 06:55 AM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
  • hinisa
    Xiaomi router freezes at boot after re-capping
    by hinisa
    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
    07-08-2023, 05:58 AM
  • i19
    Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
    by i19
    Hi
    I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
    Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
    I want to use an CH341A (new model with 3.3v) to flash it.
    My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
    Any tips on how to connect to it? Maybe something...
    08-20-2024, 06:50 AM
  • DeanWy
    WD Sentinel DS5100 (NAS) boot issues
    by DeanWy
    I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
    It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
    There...
    07-30-2024, 04:13 AM
