Hitachi P50H401
  • NickLoC
    • 80
    Hitachi P50H401
    My TV went out. Will turn on, no picture, blue light just blinks. Buffer board has a burned IC. Have 2 blown caps on the power supply. Disconnected the other buffer board and tv powers on and displays half a screen. Was wondering if anyone has replaced just the burned IC? I can get one on ebay for around $20. A used buffer board is $80.
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: Hitachi P50H401
    You should be able to repair the problem by replacing the ic. I had this model and had four bad ICs and had them all replaced which fixed it.
    • NickLoC
      • 80
      Re: Hitachi P50H401
      How did you know which ones were bad? How did you replace them? I don't have a hot air rework station.
      • Glitcher
        • Mar 2013
        • 673
        • USa
        Re: Hitachi P50H401
        There should be 2 little ceramic capacitors parallel to each other next to each IC if I remember correctly. Measure across one for resistance and see if it is shorted, if it is than the IC next to it will be bad. The ICs for this was relatively expensive so I ended up sending it in for repairs from someone on ebay.
        • SlickClick
          • May 2011
          • 91
          Re: Hitachi P50H401
          Do these have panasonic guts..?
          • NickLoC
            • 80
            Re: Hitachi P50H401
            I will have to check them. So if the tv turns on and displays half the screen with one buffer plugged in, does that mean the other boards are ok? I was wondering if I could use a heat gun and a solder iron and replace myself. Then I guess silicon around the chip.
            • Glitcher
              • Mar 2013
              • 673
              • USa
              Re: Hitachi P50H401
              I usually scratch off as much of the silicon off the chip as possible and then remove the chip with a heat gun and aluminium foil. It's a bit difficult though
              • NickLoC
                • 80
                Re: Hitachi P50H401
                I might try it. The hardest part I think would be soldering the new chip.
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  Re: Hitachi P50H401
                  Soldering the chip should be pretty straight forward. But you have to be careful not to damage the traces when removing the old one since it is held with some silicon that will add extra force when trying to lift it.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • sotodefonk
                    Help finding the correct model of a T-Con board on my Hitachi TV
                    by sotodefonk
                    Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                    I opened the tv to access the board and took the shared pictures of the T-Con board.
                    I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                    I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                    Inspecting...
                    06-28-2024, 04:39 PM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
