Samsung LE32R748BD - possible screen fault
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    HI all
    I got this tv from someone who told me the screen was good but cant remember the fault, she said they tried replacing something but couldnt tell me what
    do you think the below is a screen fault or incorrect main etc ?
    the screen comes up for a second with the picture below and goes round in a loop
    Re: Samsung LE32R748BD - possible screen fault
    Doubt screen is bad.
    Looks like a main board fault.
    If it had bad caps you should reset eeprom (pins 5-6)
    • noledud
      • Dec 2013
      • 413
      • united kingdom
      hi tom
      do you know where it is on this board
      iv found ic3004 it a 24c32wp?
        I'm not sure but the info is probably elsewhere on the 'net, I think there is a Samsung service bulletin about replacing/resetting EEPROM after capacitor replacement.
        • noledud
          • Dec 2013
          • 413
          • united kingdom
          thanks tom - the chip i found i believe is the eeprom - i have tried several times and it has changed the box slightly i can see the blue channel box just but just goes off again, im going to try a replacement main
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • arbitarytwist
            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
            by arbitarytwist
            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
            03-01-2025, 01:16 PM
