TV Samsung UE40MU6405U, not standby (after power failure)
  • Espartaco Smith
    • Dec 2024
    • 3
    • Spain
    Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
    After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
    The power supply is: L40E6_KSM (BN44-00875A)
    The main board: BN41-02568B
    The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
    I've also checked the voltages on the main board, and they also seem to be correct. The last thing left to test, before taking the TV to the recycling center, is whether the contents of the 25Q40CL chip are corrupted (based on what I've read in other posts on the forum).
    So, I proceeded to read the contents of the IC with a CH341A and I've attached it here. At first glance, it doesn't seem bad (at least I don't see garbage data at the beginning, as I've seen in other cases on the forum ) though I don't have the expertise to determine what's right or not.
    If someone could give me a hand, that would be great.
    Thanks in advance
    Last edited by Espartaco Smith; 12-17-2024, 02:20 AM. Reason: A forget attach file :)
  • lotas
    • Jan 2016
    • 4805
    • Russia
    Try it, don't forget to set and write status registers (0x88, 0x42) after writing the corrected dump.​
    • Espartaco Smith
      • Dec 2024
      • 3
      • Spain
      Thank you so much! My TV is now working again.
      Best regards!
      • lotas
        • Jan 2016
        • 4805
        • Russia
        Best regards!
        Ok!
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Chris24
          Samsung UN58J5190 - Doesn't Power on and has Standby
          by Chris24
          Hey everyone - I have a Samsung UN58J5190 with these symptoms: Does not power on, has standby light, standby light blinks 5 times after pressing "power on." When plugged in the power supply is making a very faint ticking sound, and this goes away when pressing power on.
          Following instructions from the great team here in recent posts for Samsung with similar symptoms, I did the following tests:
          I tested with mainboard disconnected from power supply - backlights do not come on (symptoms no change/5 red blinks)
          I tested with T-Con disconnected...
          10-12-2021, 12:43 PM
        • nathan425
          Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
          by nathan425
          Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
          Symptoms:
          • - no power
          • - no standby LED
          What I've done so far:
          - confirmed power supply is OK
          -- CN201 #4 showing 5.3V
          -- BD207 showing 5.3V
          -- removing the cable between the main board and the power board turns on the backlight.
          Pushing the power button on results in no change to any of the pins connecting the two boards.
          - function assembly appears to be NO GOOD
          -- there is no voltage showing on any of...
          11-01-2023, 06:34 PM
        • amennone
          Samsung UE50NU7090U , no power , no led standby
          by amennone
          By inserting power, on the diodes DM856...Dm859, there are 9 volts, when you press the power button the voltage is 12 volts, voltage present for a few seconds, then returns to 9 volts
          The power LED remains off, always.
          Reprogrammed Ic 503 = 25Q40 and IC 501 = 25Q80, downloaded from the site
          The situation remained the same​
          https://**************/dump/lcd_pdp_...oogle_vignette...
          11-17-2024, 04:28 PM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
