I have a Samsung UN55B6000VFXZA BN02 that tries to power on but the relays just click with no video or backlight. When I disconnect the power board from the main board, the backlight comes on. I have checked the power board (BN44-00271A) fuses and they seem fine. I also checked the 30 output pins for the voltages and grounds printed on the board all seems acceptable. I don't have a repair manual for it yet, so I don't know the procedure to check the H-sync, Inv err or BL On/off properly. Any help or suggestions to identify the failure and how to fix would be greatly appreciated. The main board is BN94-02657X. I'm having trouble finding a P/N on the T-con board, but there is a pink dot in a box by a V546H1 marking.
Samsung UN55B6000VFXZA BN02 just clicks, no power on, no video
Re: Samsung UN55B6000VFXZA BN02 just clicks, no power on, no video
Thanks for the help Ltank. I have a UN40B6000VFXZA that uses the same main board with an M final digit rather than the X on the 55's board. I swapped the main board and the 55" set started up fine. I have ordered a main board and should be able to get the 55" set going as soon as the board arrives.Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
The models launched in 2018 and 2019 respectively.... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
• Have obtained Samsung schematic & service documents - Can upload if helpful.
• Have read ALL applicable threads
• C1818 and CP820 replaced as low hanging fruit
• CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
• VCC pin (18) of PFC... -
by alltvrepairsHi,
I have confirmed that I have a mainboard problem.
I have tracked no hardware issued on board so might be a software dump required.
I have searched a bit but wasn't able to find anything for my screen:
Here are some more details:
Panel: cy-nn065hgev1h
Main: BN94-14180M P08F
Your help much appreciated!
... - Loading...
