Sony KD-60X690E 6 Blinks, no image
  • x_orange90_x
    • May 2015
    • 746
    I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
    I will be testing the LEDs probably tomorrow night nonetheless.
  • Storyteller12
    • Jun 2020
    • 625
    It’s most likely back lights as you mentioned since that’s Sonys code for backlight failure.
    You can ground the wire named backlight err to the chassis and that should bypass the shutdown so you can verify the tv works and confirm it’s the backlights.
    • x_orange90_x
      • May 2015
      • 746
      Thanks for the informative reply! I will try this! I'm guessing that wire will be on the connector to the main board?
      • Diah
        • Feb 2013
        • 6460
        not a good idea to shorting the BL-.error to chassis.... as it will go high if there are issue at BL... just measure it if it goes high and be sure what kind of BL you have edge or direct
        • x_orange90_x
          • May 2015
          • 746
          What will happen... Damage to the power supply?
          • Diah
            • Feb 2013
            • 6460
            of course it will toast it..LOL
            the correct way the wire which it go from the PSU socket to MB of BL _err slide it out from the socket at PSU and connect to GND,, so it should
            • x_orange90_x
              • May 2015
              • 746
              Plugged my tester in to the LEDs and the backlights light up, but they're blue.. So definitely bad backlights.
              • EazyBone
                • Jun 2023
                • 1356
                • United states
                Blue definitely means bad backlights but that doesn't mean it's your code. I have this exact TV and it has blue lights and doesn't throw any code.
                It still probably is the backlights but just saying blue won't throw the code probably. I know many Sony's that are blue no code
                • x_orange90_x
                  • May 2015
                  • 746
                  Several Reddit users were having the 6 blink code and it went away after replacing the backlights. Some even swapped out the power and main boards prior.
                  What's odd though is that I couldn't see the Sony logo or anything else with with a flashlight when the LEDs were plugged into the power supply. What I did in the video is unplug it from the power supply and stick the tester probes into the plug and taped them in place, then I plugged the the tv in and turned it on. That's when I was able to get the logo.. But it keeps rebooting every few seconds. I don't think the red light was flashing though during all of this. I already tore it down last night, or else I would have repeated this setup to confirm whether or not it was flashing... Can't see the light on my video. I already ordered the backlights, should come early to mid next week.
                  • EazyBone
                    • Jun 2023
                    • 1356
                    • United states
                    Got to love them blue lights there's a ton of street lights down here in Florida that are all blue
                    • Storyteller12
                      • Jun 2020
                      • 625
                      They just need the quantum dot filters to make them white again. lol
                      • Storyteller12
                        • Jun 2020
                        • 625
                        Isn’t that what I said? The chassis is ground
                        • EazyBone
                          • Jun 2023
                          • 1356
                          • United states
                          That would be one hell of a solution 🥹🥹😁😁
                          • x_orange90_x
                            • May 2015
                            • 746
                            Finally got my backlights on Christmas Eve. I just finished the job and it's working fantastically! Thank you guys for your help and insight! I appreciate it!
                            • mauda
                              Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                              by mauda
                              I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                              Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                              05-21-2023, 11:56 PM
                            • matwan
                              Sony XR-55X90J 5 blinks
                              by matwan
                              I have problem with SONY 55X90J. After several check status is as below;
                              1. Running power board as stand alone:
                              TCON_12V =~ 12.6V
                              EVDD V On Max 24V= 19V.
                              2.
                              Running power board with TCON as stand alone:
                              Effect as below, attched.
                              3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                              "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                              Best regards....
                              09-28-2025, 04:26 AM
                            • GoodCapDude
                              Sony XBR-75X940E intermittent 6 blinks error code
                              by GoodCapDude
                              Hi everyone. First post on Badcaps!
                              I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                              09-20-2025, 06:07 AM
                            • reassor
                              Sony kd70xf8305 very very slow android logo with sound
                              by reassor
                              Hi.
                              Power is ok
                              Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                              Should i force update? If so how?
                              I did reset.
                              Mainboard Looks pristine.
                              Very wierd.
                              10-30-2023, 05:59 AM
                            • Ihandyrepair
                              4 red flash led 65X950G boot Sony and android logo but then black
                              by Ihandyrepair
                              HI guys
                              I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                              here is the issue
                              I have Sony and android logo. but then 4 led red flash lights front of the tv
                              I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                              but then I get black screen and 4 red flash light at the front LED
                              but I get 3 led flash on the LED driver board.
                              I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                              so I tried...
                              07-11-2024, 01:45 AM
