Hisense 55” LED EDGELIT TV QUESTION
  • brithepi2k
    • Dec 2024
    • 26
    • Scotland
    I just done a repair on the edge lights on a Hisense Tv, I scraped all of the black stuff that holds the screen onto the frame, what do I use to stick the screen back onto the frame? I think maybe RTV Black Silicone sealant but just wondering if anyone knows what I can use to stick the screen back on so that it sticks and the light doesn’t shine out the edges.
    thanks in advanced
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Go to eBay type TV screen tape. Take your pick.
    • mecha1166
      Reattaching new edge to edge LCD panel to tv frame - Hisense 55a6g and others
      by mecha1166
      Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
      06-13-2024, 02:28 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Kemer
      Graphics Card mounting frame
      by Kemer
      Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
      As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
      I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
      What worries me right now is the possibility that...
      09-14-2024, 08:57 AM
    • ezenia
      PS4 controller left stick potentiometer replacement issue
      by ezenia
      Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
      So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
      I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
      09-30-2023, 02:19 PM
    • tomketcz
      schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
      by tomketcz
      Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
      10-01-2025, 03:13 AM
