UE65ES8000U SAMSUNG REBOOTING
This topic has been answered.
  • sordids999
    • May 2013
    • 2149
    Hi
    TV stuck in reboot
    If I disconnect the cable which I think is the WiFi the TV stays on
    Removing cable from main to PSU backlights stay on
    Also upon further inspection CNM801 cable 20 pin is burnt
    Does anyone know what would cause this issue
    ​​​​​​thanks
  • Answer selected by sordids999 at 12-21-2024, 09:57 PM.
    sordids999
    • May 2013
    • 2149
    Sorry my bad the sensor is connected at the top with the camera I thought the Samsung blue light at the bottom was the sensor
    Remote now working once I replaced the camera attachment with sensor
    So it seems there was two faults
    WiFi module
    Led sensor
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      Shorted out WiFi board?
      Does the TV turn on and function properly without the board connected?
      • sordids999
        • May 2013
        • 2149
        If I remove the WiFi card the TV is fine and I can use the TV using the button on the back of the TV but the remote doesn't seem to work
        • Davi.p
          Hobbist
          • Sep 2009
          • 4263
          • Italy - Milan
          shorted wifi module, but i do not Remember well, maybe the ir board is cabled into the same connector as wifi module i think
          • sordids999
            • May 2013
            • 2149
            Yes it seems this connector controls the ir,WiFi,Bluetooth etc
            • Davi.p
              Hobbist
              • Sep 2009
              • 4263
              • Italy - Milan
              ok now i don't know if a replacement part is available, this is a 2012 set i think, plus maybe the burnt wire near the connector need attention
              • KYBOSH
                • Oct 2011
                • 581
                • Unknown
                What's the part number on the combo module (wifi, ir, bt)?
                • Davi.p
                  Hobbist
                  • Sep 2009
                  • 4263
                  • Italy - Milan
                  You can further inspect the thing.. if the wifi module has no burn signs, you can wire it flying mode to a male usb A connector and put it in a PC, if the module is recognized then the possible fault is not the module but the burnt wire only.. that burnt contact is a very very common issue in the es7/8000 ..
                  Adding that maybe Samsung did a wrong calculation of the B5V line wire section and it must be reinforced with another wire..
                  • Davi.p
                    Hobbist
                    • Sep 2009
                    • 4263
                    • Italy - Milan
                    wifi/bt internal modules are electrically usb modules
                    • sordids999
                      • May 2013
                      • 2149
                      I've replaced the WiFi module and it's stopped rebooting but I still can't get the Samsung remote to work with the TV the back button is fine
                      I have even replaced the Samsung sensor
                      • sordids999
                        • May 2013
                        • 2149
                        WiFi module
                        Led sensor
                        • Davi.p
                          Hobbist
                          • Sep 2009
                          • 4263
                          • Italy - Milan
                          sensor=ir receiver? ok
                          • sordids999
                            • May 2013
                            • 2149
                            Sorry yes I bought a kit which consisted of WiFi module and camera/ir receiver and TV now is fully functioning
                              09-07-2024, 05:50 AM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • plytek
                              Samsung QE50Q60TA rebooting
                              by plytek
                              Hi all.
                              I'm trying to fix my Samsung QE50Q60TA TV.
                              IT's rebooting every few seconds.
                              I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
                              Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
                              Can anyone suggest what I can test and do to get it working again please?...
                              02-08-2025, 06:02 AM
                            • unimatrix93
                              SAMSUNG UE55TU7002KXXH rebooting
                              by unimatrix93
                              Hello everyone, I'm working on a Samsung TV that constantly rebooting.
                              MB/PSU unit: BN9654185QE
                              It loads up to the main menu then as soon as the backlight goes brighter it reboots.
                              First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
                              Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
                              Also I have to note, that the MB/PSU combo gives out a very noticible...
                              04-07-2025, 09:49 AM
                              09-06-2024, 11:40 PM
