Panasonic Viera TH-P42S10A SOS 5 Blinks
  • DoubleDratt88
    • Aug 2013
    • 51
    Re: Panasonic Viera TH-P42S10A SOS 5 Blinks
    Thanks tw!
    I've had a few other things to do lately so this got put aside but will get into again soon.
    IC773 and 771 look suspect, Q701 702 i'm also suss on and will confirm out of circuit later this time.
    I reckon it's one of those little buggers i missed last time around - even though i was looking at them on a list in red after seeing your 5081 experiences.
    In any case that sounds like a very similar problem, closer than others. I'll have a good read and get back into later tonight hopefully. I appreciate the info very much!
    • uk_rules_ok
      • Feb 2017
      #42
      Originally posted by DoubleDratt88
      And got the bourns ultra-fast diodes for D865 from element14 in the end.
      Please could you tell me the part number of D865
      Regards,
      Andy.
      • Ancient Plasma
        • Jun 2020
        I was able to repair a Panasonic TC-P42G15 Plasma with the same symptoms listed by the OP (buzz/hum followed by relay click at power on, 5 Blink SOS code, no signal, short across SC2) using a Panasonic Repair Kit.
        Repair Kit:
        PART: TNPA4844
        MFR: PANASONIC
        INV: Y-SUS REPAIR KIT
        Repair Kit contents (15 components)
        -3 x 2PG011 / RJP56F4A (Q402, Q403, Q404 - IGBT TO-220F)
        -3 x RJP4585 (Q422, Q423 Q424 - MOSFET TO-220F)
        -6 x 7.5ohm 1/3W (R402, R403, R404, R422, R423, R424 - Resistor SMD)
        -1 x RJK6026 (Q660 - MOSFET TO-220F)
        -1 x RJP6065 (Q661 - MOSFET TO-220F)
        -1 x RF101L4S (D865 - Diode SMD)
        All components were replaced except the resistors which measured fine on the SC board. The diode was shorted. I did not evaluate all of the TO-220s as some were definitely bad and I decided to replace them all. TV works as new after the repair.
        The following reference was helpful during the repair:
        Panasonic TCG46P15 Service Manual
        Hope this helps someone else trying to revive an old plasma TV.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
          After all of...
          07-13-2024, 08:14 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
        • mmischni
          Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
          by mmischni
          Greetings friends,
          I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
          First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
          09-06-2017, 08:52 PM
